Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer turns on, but screen won’t light up.
When I power on my computer, I can hear the computer start up but the screen is dark/faint.
Low Brightness
To fix this, just locate the F3 key at the top of the keyboard and press the button until you see the screen beginning to become brighter.
Hard Reset
If the computer is turned on and the screen is still dark, the computer could require a hard reset. To go about this, locate the power button at the top left of the keyboard and hold it down for approximately 8-10 seconds. After that, turn the computer back on and a start screen should appear. Use the arrow keys to navigate to “Start Windows Normally’ and press the enter key and windows should begin to power on.
Faulty Screen Assembly
If the screen is still dark after attempting to turn the brightness up, then the screen assembly is faulty and will need to be replaced.
Everything is running but the screen is cracked/partially lit.
When the computer turns on, the screen is only partially lit up or cracked.
Broken Screen
Since the screen is only partially lit or cracked, the screen will need to be replaced.
The laptop is making very odd noises.
When my laptop is on, it is loud and making very odd noises.
Clogged Fan
If the laptop is making noises, this could very well be because the fan has accrued some debris such as dust or other substances. Try using some canned air or other type of spray to remove the debris from the fan.
Faulty Fan
The fan could be partially broken or maybe not even working. Consider purchasing a new fan for replacement.
When I plug my laptop in, it will not charge.
After plugging the laptop in from the charging cable, the laptop shows no sign of charging.
Charging Cable Plugged Incorrectly
If the laptop is not charging with the cable plugged into the computer, double check that the power adapter is plugged into a working outlet and that the wire has no kinks or defects to it. If everything looks good on the cable, there may be an issue with the laptops battery.
Faulty Battery
Since the laptop is not registering a charge from the charging cable, the battery may not be capable of holding a charge, causing the battery to be malfunctioning. Consider replacing the battery.
There is no sound coming from my laptop’s speakers.
When I try to play a video or music from my laptop, there is no sound coming from the speakers.
Volume Too Low
Locate the F11 and F12 keys at the top row of keys on the keyboard. Press the F12 key until the volume begins to increase.
Volume Mixer muted the Program.
The windows software has an audio mixer program that enables users to control volume for each program that’s on. Locate the volume mixer on the bottom right of the screen (next to the date and time). It’s the speaker icon. Right click on the icon and left click the open volume mixer. Check if volume is muted on the application program you are using.
Wrong Device Selected on the Volume Mixer.
Sometimes the output device settings gets changed (when using earphone or other speaker devices). Locate the volume mixer and right click the icon. Left click the “Open Sound Settings.” On the very top, of the page will be the “choose your output device” tab. Left click on the tab and make sure you have the desired device selected.
Faulty Audio Driver
If all of the above options do not resolve the issue, the audio driver may need to be replaced. Consider purchasing one for replacement.
Kristen Gismondi
109,535 Reputation
271 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 26
All Time: 455
