Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop will not turn on
The laptop will not respond, or show any signs of powering on. Try holding the power button down for several seconds.
Wrong Charge Cable
If the computer is being charged with the wrong charge cable, the PC may not receive the proper voltage necessary to ensure charge. Make sure the charge cable is correct for this model of HP laptop before utilizing it to charge your PC.
Battery Needs to be Charged
Connect the charger to the PC and ensure that the charging indicator light is on. If the PC does not power on check the outlet by plugging in another device to ensure the issue is not the outlet.
Battery Needs to be Replaced
Remove the battery from the PC, and connect the PC to an electrical outlet with an active current. If the PC powers on while the battery is removed, the issue is not the power supply, but the battery itself. You’ll need to replace the battery. The computer will need to be run on AC power until the battery is replaced. Check out our battery replacement guide.
Failed to connect to network
The laptop will not connect to a wireless network. The device will commonly say, “no network connection,” or, “you are not connected to the internet.”
Network is Down
Ensure that your internet is functioning properly by checking the status of the network on your wireless router or modem provided by your service provider.
PC Needs System Restore
Perform a system restore to rollback the laptop to an earlier date when the laptop was connected to your network; moreover, this will not delete your data.
Power Cycle the Network
Shut down the laptop, and unplug your router, and your modem. Wait for at least 45 seconds. After the 45 seconds, plug the modem and wait for the modem to come back online. Plug the router and wait for the router to come back online. Turn your laptop back on, and test your network connection.
Failed to connect to Bluetooth
The laptop does not connect to devices that seek a Bluetooth wireless connection. This issue is further related to the connection, or lack thereof, to the wifi.
Laptop is not Connected to WIFI
Ensure that the device is connected to a wireless network. The wireless bluetooth will not work without a proper internet connection. A proper connection ensures that the device is capable of picking up a bluetooth signal to connect to the device.
Laptop is Already Connected to Another Device
It is possible that the PC is already connected to another device and therefore, cannot connect to a new device. In order to disconnect the other device go to settings, bluetooth, right click on the device already connected, and select disconnect. After, select the device you desire to pair with your device.
Laptop May Require a Restart
It is possible that the device may require a restart to resolve connectivity issues. To do this close all tabs open on your device, turn the device off, and then turn the device back on. After, try and pair your device.
Laptop has a Blank Screen
The laptop will not display any visuals, but shows signs of being on.
PC Needs a Hard Reset.
The laptops screen may be blank due to a software update, virus, or bad cables. Start by hard resetting your device. First turn your device off and unplug it from any cables and devices attached and remove the battery. Then hold the power button for 60 seconds. After, attach your battery and attach the PC to the charger. Now try to start your laptop again.
Screen Needs to be Replaced.
It is possible that the screen of the device is broken. Try to hook your device up to another monitor to see if the display still works. If the display is clear on a different monitor, then the screen itself could be faulty. Please see the ++screen replacement guide++ for more information.
Motherboard is Defective
The screen may appear blank because the motherboard is defective. Please see the ++motherboard replacement guide++ for more information.
PC is Running Slowly
The laptop processes and opens new applications at a slow rate. The 2.4GHz 4th generation Intel Core i3-4000M Processor may be defective or has lost processing power over time.
Too Many Large Applications
Try removing unused applications from the hard drive of the device. Unused applications can take up a significant amount of storage and slow other tasks on the device. Freeing up space may result in faster processing speeds.
PC Has too Many Files on Hard Drive
Delete temporary files and consider cleaning up the hard drive. Temporary files, such as internet downloads and cookies may include harmful malware that slows down the processing ability of the device. Clearing these downloads from the device may result in the device running faster. Likewise, consider a third-party malware cleaning application and run it on the device.
Audio Does Not Work
The audio is not heard coming out of the speakers or is muffled.
Audio is Not Turned On
First, check to see if the audio settings are turned on. If the audio settings are set off, turn them on and test the speakers. If, still, no sound is coming out, the speaker components may be broken and would then need to be replaced.
Audio Format is not Correct
If there is no sound, try switching the audio format and hit “Test.” If the audio issue persists, uninstall and reinstall the audio driver. Then, use a soft cloth to clean and remove dust from the device’s speaker.
Audio is Being Blocked by Dirt
Over time, dust and other debris can get into the speaker output and can muffle the audio that the device is producing. Take a clean, dry cloth and use it to clean the inside of the speaker. As a result, the audio quality should improve.
Author
with
Courtland Hollis
51 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 14
All Time: 597
