HP Pavilion 17-e146us Screen Replacement
    1. HP Pavilion 17-e146us Screen Replacement, Screen: step 1, image 1 of 2 HP Pavilion 17-e146us Screen Replacement, Screen: step 1, image 2 of 2
      • Open the laptop.
      • Remove the two stickers on the lower left and right-hand corner of the laptop screen.
      Ask FixBot
    2. HP Pavilion 17-e146us Screen Replacement: step 2, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the two 5 mm screws in the lower left and right-hand corner of the laptop screen.
      Ask FixBot
    3. HP Pavilion 17-e146us Screen Replacement: step 3, image 1 of 2 HP Pavilion 17-e146us Screen Replacement: step 3, image 2 of 2
      • Place a spudger or opening tool between the laptop screen and the plastic laptop frame.
      • Apply light pressure to the spudger to separate the plastic laptop frame covering the edges of the laptop screen.
      • These silver pieces cover the laptop hinges and will need to be removed as well.
      Ask FixBot
    4. HP Pavilion 17-e146us Screen Replacement: step 4, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the four 4 mm screws in each corner of the laptop screen.
      • This will separate the laptop cover from the laptop screen frame.
      • Hold the laptop cover securely to prevent damage.
      Ask FixBot
    5. HP Pavilion 17-e146us Screen Replacement: step 5, image 1 of 2 HP Pavilion 17-e146us Screen Replacement: step 5, image 2 of 2
      • Using a Phillips #0 screwdriver, remove the four 3 mm screws on the side of the frame, one in each corner.
      • This will release the laptop screen from the frame.
      • Hold the laptop screen and frame securely to prevent damage to the motherboard attachments.
      Ask FixBot
    6. HP Pavilion 17-e146us Screen Replacement: step 6, image 1 of 2 HP Pavilion 17-e146us Screen Replacement: step 6, image 2 of 2
      • Remove laptop screen.
      • While removing the laptop screen, be careful not to destroy the tape connection or break the motherboard.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 71
All Time: 960
