Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop Suddenly Shuts Off (Overheating)
During normal use, the computer shuts itself off suddenly. The bottom of the laptop and the keyboard area are hot, and the fan may have been running loudly up until the laptop shuts off.
Dusty Fans
The HP Pavilion 15-ba003ds is designed to efficiently transfer heat away from the processing unit with the fans equipped on the side of the frame by the keyboard. When this is not the case, the laptop is suffering from overheating and will not operate correctly. One reason is that the fans may be filled with dust from use, and may not be working efficiently. You can refer to this guide to fix that issue.
Processor Paste is Old
The HP Pavilion 15-ba003ds uses heat pipes to connect your processor to the fans in order to transfer heat away from your computer. However, the paste that transfers heat from your processor to the heat pipes might be getting old and is no longer doing its job. In that case, you can follow this guide in order to make that right!
Fans are not Working
If the fans are not working on your HP laptop, maybe it’s time to replace the whole unit. This will take a bit longer than the above solutions and a little bit of expertise. You can follow this guide here to get that done.
Blank Screen or no Display
When you turn your laptop on and also see the LED status lights are flashing, but the screen remains blank and does not display anything.
Graphics Driver is not Working or Faulty Motherboard
If you have an extra monitor or TV around, you can try to connect your laptop to the display and try to see if it displays anything. If there is a display, we know that there is a problem with the screen, and you can replace that using this guide. If there is no display appearing on the unit, there is a problem with your motherboard or graphics driver.
Software Issue
Some software/applications might be using more CPU power or running in the background. Just shut down the laptop and restart it.
The Computer is Frozen with a Blue Screen
Your screen is blue with the message that Windows has crashed.
Something Went Wrong with the Newest Update
Most likely, something went wrong with one of the newest software or drivers installed into your system. With that being the case, we can roll back the changes made to your system using a nifty Windows 10 feature called System Restore.
You have Dangerous Viruses or Malware
It’s possible that you might have downloaded some nasty viruses or malware that hasn’t been found on your computer already. In that case, you can download a free trial of some popular scanners online, such as MalwareBytes™ to run a scan and see if there is anything on your computer that shouldn’t be.
Your Hard Drive or Memory is not Connected Correctly
It could be that somehow, your hard drive or memory could have shifted and is now incorrectly communicating with your computer. In this case, you can follow this guide in order to fix that.
Your System Memory is not Functioning Correctly
If all else fails, it might be possible that your system memory is not functioning correctly. You may have to purchase a set of compatible system memory and perform a memory replacement. This can be done if you follow this guide here.
Laptop not Charging
When you plugged an AC adapter into your laptop, you will be noticed that the laptop is not charging.
Plugged in, Not Charging
  1.  Click on the Start icon on your Windows System or press the Windows Icon Key on your keyboard.
  2. Type Device Manager and open it.
  3.  After the Device Manager Window shows up, go to the Battery section and click the arrow icon to expand the list.
  4.  Select the Microsoft ACPI-Compliant Control Method Battery in the list and right-click select uninstall the device.
  5.  Reboot your computer, and it will reinstall the battery driver automatically.
  6.  Unplug the AC adapter and remove the battery from your laptop.
  7. Press and keep holding the Power Button for at least 15 seconds.
  8.  Put the battery back and connect the AC adapter.
  9. Turn on your computer and look for the message ‘Plugged in Charging’ on the right-bottom corner battery icon.
After completed all the steps above, the battery not charging issue should be fixed.
Faulty Power Adapter
While connecting the laptop with the adapter and plugging into the power socket, the light on the adapter is not turned on, and then there might be an issue with the adapter, so buying a replacement would be an option.
Faulty Charging Port
If the light on the adapter is turning on while plugged into the power source and still laptop is not turning on than their might be an issue with the charging port, which can be replaced using this guide.
LI XU
334 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 31
All Time: 879
