HP Pavilion 15-ba003ds RAM Replacement
    1. HP Pavilion 15-ba003ds RAM Replacement, Battery: step 1, image 1 of 2 HP Pavilion 15-ba003ds RAM Replacement, Battery: step 1, image 2 of 2
      • Unplug the AC adapter from the corresponding socket in the laptop.
      • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
      • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
      • Carefully slide the battery out of the laptop frame and place it somewhere safe.
      Ask FixBot
    1. HP Pavilion 15-ba003ds RAM Replacement, Disc Drive: step 2, image 1 of 1
      • Use a spudger to remove the two rubber feet next to the battery.
      • This will reveal two hidden screws.
      • Save the feet for reassembly.
      Ask FixBot
    2. HP Pavilion 15-ba003ds RAM Replacement: step 3, image 1 of 2 HP Pavilion 15-ba003ds RAM Replacement: step 3, image 2 of 2
      • Use a Phillips #00 screwdriver to remove twelve 8 mm screws from the bottom of your laptop including the two screws found underneath the rubber feet.
      Ask FixBot
    3. HP Pavilion 15-ba003ds RAM Replacement: step 4, image 1 of 2 HP Pavilion 15-ba003ds RAM Replacement: step 4, image 2 of 2
      • Pull the disc drive from your laptop to remove it.
      Ask FixBot
    1. HP Pavilion 15-ba003ds RAM Replacement, Backplate: step 5, image 1 of 3 HP Pavilion 15-ba003ds RAM Replacement, Backplate: step 5, image 2 of 3 HP Pavilion 15-ba003ds RAM Replacement, Backplate: step 5, image 3 of 3
      • Use a Jimmy to pry off the black backplate.
      Ask FixBot
    1. HP Pavilion 15-ba003ds RAM Replacement, RAM Module: step 6, image 1 of 2 HP Pavilion 15-ba003ds RAM Replacement, RAM Module: step 6, image 2 of 2
      • To release the RAM, hold and pull the strips outwards on either side of the RAM.
      Ask FixBot
Krushnam Badami
342 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 59
All Time: 629
