HP Pavilion 15-ba003ds Screen Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
66
All Time:
714
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 minutes - 1 hour
Difficulty: Very difficult
Introduction
Go to step 1 ↓
If your HP Pavilion 15-ba003ds has a screen that is damaged or will not turn on, you might need to replace it. Use this guide to disassemble and remove your old screen without damaging any other components of your laptop.
The screen itself is a thin display module that is fastened behind the frame of the upper portion of your laptop. Aside from obvious cracks, symptoms of a bad or damaged screen include the appearance of “dead” pixels, blotches, or a screen that is having trouble reaching its full brightness.
Before using this guide, check the settings on your device for brightness and contrast to see if the image cannot be corrected.
This instruction requires a steady hand and attention to technique. A mistake in this process could result in damage to the screen or wires within your HP Pavilion.
Check to make sure that you have all of the required tools and parts before beginning this guide.
Before you get started, power off the device completely and disconnect the device from any external power source.
Tools
    1. HP Pavilion 15-ba003ds Screen Replacement, Screen: step 1, image 1 of 3 HP Pavilion 15-ba003ds Screen Replacement, Screen: step 1, image 2 of 3 HP Pavilion 15-ba003ds Screen Replacement, Screen: step 1, image 3 of 3
      • Apply firm pressure and slide the metal spudger along the outside edges of the front panel screen.
      • When using the metal spudger, be careful not to press into the plastic panel too hard. It may damage internal cables or the panel.
      Ask FixBot
    2. HP Pavilion 15-ba003ds Screen Replacement: step 2, image 1 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 2, image 2 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 2, image 3 of 3
      • Continue sliding the metal spudger to the bottom of the screen.
      • Don't pull on the frame outwards as this will put pressure on the panel and damage it.
      Ask FixBot
    3. HP Pavilion 15-ba003ds Screen Replacement: step 3, image 1 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 3, image 2 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 3, image 3 of 3
      • Flip the laptop so the bottom is facing upwards.
      • Using the metal spudger, separate the plastic panel off the screen.
      Ask FixBot
    4. HP Pavilion 15-ba003ds Screen Replacement: step 4, image 1 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 4, image 2 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 4, image 3 of 3
      • Once the panel is separated from the screen, gently pull it off and set it aside.
      • Remove two 6mm Phillips #00 screws from the bottom of the screen.
      Ask FixBot
    5. HP Pavilion 15-ba003ds Screen Replacement: step 5, image 1 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 5, image 2 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 5, image 3 of 3
      • Remove two 6mm Phillips #00 screws from the top of the screen.
      Ask FixBot
    6. HP Pavilion 15-ba003ds Screen Replacement: step 6, image 1 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 6, image 2 of 3 HP Pavilion 15-ba003ds Screen Replacement: step 6, image 3 of 3
      • Flip the screen down.
      • Remove the tape from over the connector.
      • Pull out the connector using your fingers.
      Ask FixBot
    7. HP Pavilion 15-ba003ds Screen Replacement: step 7, image 1 of 1
      • Lift the screen away from the laptop.
      Ask FixBot
Joseph Chia
355 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 66
All Time: 714
