Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Computer Will Not Power On
The computer does nothing when the power button is pressed.
The Battery is Dead
Your computer will not turn on without the cord plugged in. Plug your computer into a power outlet. If the light turns on, your computer is charging. Charge your computer for at least 30 minutes and see if it turns on.
If this does not work, you may need to recover your computer using a Mac or a PC and a flashdrive or an SD card. Install and open Google Chrome and the recovery app on your other device. Click "Get started" and select a model from a list. Click "continue." Insert the flashdrive or SD card into your Mac or PC, and choose the flashdrive or SD card in the dropdown menu. Click "continue" and "create now." Once a message appears saying your recovery media is ready, remove the flashdrive or SD card from your computer. Open up your Pixelbook, hold Esc + Refresh, press power. Once a message comes on the screen, remove your fingers from Esc + Refresh. Insert the flash drive or SD card, and follow the instructions on the screen.
The Battery Needs to be Replaced
Try powering on your computer. If this does not work, replace the battery.
The Motherboard Needs to be Replaced
If nothing else works, the motherboard may be faulty. Use this guide to replace the motherboard.
The Battery will not Charge
Your computer will turn on, but will not hold a charge.
The Power Cord/Charging Port is Broken
If your computer does not charge, make sure the outlet is working. Unplug the cord from your computer and the outlet and replug it into your computer, then the outlet. If the light on the charging cord glows, your cord is receiving charge. Leave your laptop to charge for thirty minutes, and see if it works. If the cord is not receiving charge, double check the outlet to see if it is correctly plugged in. If it still does not light up, you may need to replace the charging port or the power cord.
The Battery is Faulty
First, try resetting your laptop with a hard reset. Hold down reset+power to restart your computer. Leave your laptop to charge for thirty minutes, and check back to see if it works.
If your battery still will not charge, you can check your battery’s health by pressing ctrl+alt+t to open a crosh window. Type battery_test 30 into the opened window. If your battery health is significantly lower than 100% (use your best judgement), you should replace your battery.
The Battery Dies Quickly
The battery charges, but dies faster than it should.
The Computer Settings Need Adjustment
Try adjusting your settings to make your battery lasts longer. Keep your brightness at 50%, make sure your Wi-Fi signal is strong, and close your browser extensions. To delete an unnecessary extension, go to Launcher at the bottom of your screen, click on "app list", right click on the app, and select "Remove from chrome".
If your battery health is near 100%, check your battery discharge rate by typing battery_test 60 into the crosh window. If your battery discharge rate is more than the 15-20% range, try adjusting your settings to make your battery last longer. Keep your brightness at 50%, make sure your Wi-Fi signal is strong, and close your browser extensions. To delete an unnecessary extension, go to Launcher at the bottom of your screen, click on "app list", right click on the app, and select "Remove from chrome". If your battery still loses charge quickly, you should replace your battery.
The Sound is Distorted
The sound is unclear, and static can be heard along with the audio.
The Sound Card has a Software Driver Glitch
If the sound coming out of your computer's speakers is distorted, first try restarting your computer. If this does not help, try to hard reset your computer by pressing the refresh+power buttons.
The Sound Card Drivers are not Updated
Go to the start menu search bar and search for “Device Manager”. Once there, look for "Sound, video, and game controllers" in the list of devices. Right click on your audio device and select “Update Driver Software” and “Automatically Search for Updates”. Make sure your computer is connected to the internet for the update to be successful.
The Sound Card Needs to be Replaced
The computer's speakers sound perfect, but the headphone jack isn't working. First, try using a different set of headphones. If the headphone jack still does not work, then the jack may be broken. This can be fixed by replacing the sound card because the headphone jack is built into the card.
The Touchpad will not Respond
When trying to use the touchpad, it does not move the cursor and/or does not click.
The Computer has Crashed/Frozen
Check to make sure the computer has not crashed by giving it other commands. Try pressing ctrl+alt+delete at the same time to bring up the Task Manager. If nothing happens, try restarting the computer and see if the touchpad responds once it has rebooted.
The Touchpad is Disabled in Settings
If possible, find a USB mouse to use while navigating through these next steps. If a mouse is not available, you can use the keyboard (tab, arrow keys, and Enter) to navigate.
First, go to the search bar in the start menu and type “Change Mouse Settings”. Under the "Properties" section, look for "touchpad settings" and make sure the touchpad is enabled. Adjust any other settings to your liking and press "Apply." Now try testing the touchpad.
The Touchpad Drivers are not Updated
If possible, find a USB mouse to use while navigating through these next steps. If a mouse is not available, you can use the keyboard (tab, arrow keys, and enter) to navigate.
Go to the start menu search bar and search for “Device Manager”. Once there, look for your touchpad in the list of devices. Right click on the device and select “Update Driver Software” and “Automatically Search for Updates.” Make sure your computer is connected to the internet for this update to be successful.
The Touchpad is Faulty
If none of these solutions are successful, your touchpad may be defective. Continue to this guide for help on replacing the touchpad.
Author
with
Derrick Unger
361 Reputation
2 Guides authored
Cal Poly, Team S18-G1, Livingston Winter 2018 Member of Cal Poly, Team S18-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G1
4 Members
72 Guides authored
3 Comments
The Touchpad is Disabled in Settings ¶
No, it isn’t
Bill Motley - Reply Share
Keyboard backlight is not working and some keys not working, esc key, 1, Q, A, Z. How can i disconnect and connect keyboard?
LaCzar - Reply Share
Did you figure this out? Touchpad stopped working and now some keys don’t work. Z, raise volume, search, left shift
Michael Bellavia - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 75
All Time: 16,479
