Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Correct Time is Not Displayed
When the user turns on the device, the correct time is not displayed
Timezone is Incorrect
  1. Begin on the Home Menu
  2. Choose Settings
  3. Choose Units
  4. Choose Time Offset
  5. Enter the time that corresponds to your timezone
The Screen has Dead Screen Pixels
When the device is turned on, some or all of the pixels show only black.
The Screen's Pixels Will Not Illuminate
This could be due to damaged individual pixels on the screen. You would need to replace the screen so there is no further damage. Follow this replacement guide to do so.
Buttons are Not Interacting With The Device
When the buttons are pressed, it will take a hard press to execute an action or it will not execute at all.
Button Silicone Pegs Have Been Worn Down
Since the buttons can experience extreme use over time, their connections to the screen can shorten. To fix this, you need to replace the silicone button piece. Follow this replacement guide to do so.
Motherboard Button Sensors Are Not Reading
This could be due to the sensors on the motherboard not working properly or not working at all. The motherboard cannot pick up readings from the buttons. You need to replace the motherboard. Follow this replacement guide to do so.
Depths Are Not Being Calculated
When the device is on, the depths are not being calculated correctly, or at all.
Pins That Connect the Transducer to the Device Are Corroded
The pins on the back of the device, which connect the device to the transducer, are exposed to the elements when the transducer is not plugged in. Sometimes water, especially salt water, can get in and corrode the pins. Since they are connected directly to the back of the device, you have to replace the backing. Follow this replacement guide to do so.
Transducer May Be Corrupted
The transducer is external to the device, and the internals are inaccessible, so you need to buy a new transducer.
Device Is Not Powering On
When the power button is pressed, the device does not turn on.
The Power Cord is Not Getting Power
The problem may not be with the power cord, but with where it is getting electricity from. Try plugging the cord into a different outlet to make sure there is enough power coming into the device.
Pins That Connect the Power Cord to the Device Are Corroded
The pins on the back of the device, which connect the device to the power cord, are exposed to the elements when the device is not plugged in. Sometimes water, especially salt water, can get in and corrode the pins. Since they are connected directly to the back of the device, you have to replace the backing. Follow this replacement guide to do so.
The Power Cord Is Overheating
The problem may not be with the device itself, but with the charging cord instead. If the cord is out in the sun for a long period of time it can cause the cord to overheat. Try to unplug it, cool it down, and plug it back in. If this does not help, replace the power cord with a new one.
Garmin Striker 4 Fish Finder Overview
The Garmin Striker 4 is a popular fish finder and GPS navigation device designed for anglers. Here are some benefits and features of the Garmin Striker 4:
1. Fish finding Capability
The Garmin Striker 4 provides excellent fish finding capabilities, allowing you to locate and track fish underwater. It uses sonar technology to display a detailed view of the underwater environment, including fish, structures, and contours.
2. Clear Display
The device features a 3.5-inch color display that provides clear and sharp visuals, even in bright sunlight. This makes it easy to read and interpret the information displayed on the screen.
3. CHIRP Sonar Technology
The Striker 4 utilizes CHIRP (Compressed High-Intensity Radiated Pulse) sonar technology. This technology sends a continuous range of frequencies into the water, providing a more detailed and accurate view of fish and underwater structures.
4. GPS For Marking Waypoints
With the built-in GPS receiver, the Striker 4 allows you to mark waypoints and create your own custom maps. This feature is helpful for marking fishing spots, docks, hazards, and other points of interest for future reference.
5. Depth Contours
The device provides depth contour mapping, which helps you identify underwater terrain and structure. This information is crucial for finding potential fish-holding areas.
6. Portable and Easy to Use
The Garmin Striker 4 is compact and portable, making it easy to carry and install on different boats or kayaks. It features a user-friendly interface and intuitive controls, making it accessible for both beginners and experienced anglers.
7. Dual-Frequency Support
The device supports both 50 kHz and 200 kHz frequencies, allowing you to choose the frequency that suits your fishing needs. Lower frequencies (50 kHz) are ideal for deep water fishing, while higher frequencies (200 kHz) provide better detail in shallower waters.
8. Fish ID+
The Fish ID+ feature on the Striker 4 helps beginners easily identify fish targets on the screen. It assigns different fish symbols based on the sonar returns, making it simpler to differentiate between fish and other objects.
9. Flasher For Ice Fishing
The device includes a built-in flasher mode, which provides a real-time view of the water column. This feature is useful for ice fishing or vertical jigging, where you can see the movement of fish and your lure in real-time.
10. Affordable
The Garmin Striker 4 offers a good balance of features and affordability compared to other fish finder units on the market. It provides essential functionalities at a reasonable price point, making it an attractive option for anglers on a budget.
It’s important to note that technology and product features can evolve over time, so it’s always a good idea to check the latest specifications and features of the Garmin Striker 4 review before making a purchase.
Source - Garmin Striker 4 Review: Best Fish Finder 2024
Author
with
Jordan Snow
274 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 69
All Time: 1,607
