Up to 20% off select tools
Garmin STRIKER 4 Digital Display Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
92
All Time:
936
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 7 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you need to replace the Garmin STRIKER 4 digital display, access it with this guide. Some reasons you may be replacing the screen include dead pixels in the screen or the screen not turning on at all. Be careful when prying away the old screen to avoid any further damage to the casing.
    1. Garmin STRIKER 4 Digital Display Replacement, Backing: step 1, image 1 of 3 Garmin STRIKER 4 Digital Display Replacement, Backing: step 1, image 2 of 3 Garmin STRIKER 4 Digital Display Replacement, Backing: step 1, image 3 of 3
      • Flip the device so the back is facing up.
      Ask FixBot
    2. Garmin STRIKER 4 Digital Display Replacement: step 2, image 1 of 3 Garmin STRIKER 4 Digital Display Replacement: step 2, image 2 of 3 Garmin STRIKER 4 Digital Display Replacement: step 2, image 3 of 3
      • Remove all six 6 mm screws using a Phillips #0 screwdriver.
      • Detach and flip the backside to open the device.
      Ask FixBot
    1. Garmin STRIKER 4 Digital Display Replacement, Motherboard: step 3, image 1 of 2 Garmin STRIKER 4 Digital Display Replacement, Motherboard: step 3, image 2 of 2
      • Slide out the screen cable from the motherboard using the iFixit opening tool or your fingernail.
      • Remove the motherboard from the device.
      Ask FixBot
    1. Garmin STRIKER 4 Digital Display Replacement, Digital Display: step 4, image 1 of 3 Garmin STRIKER 4 Digital Display Replacement, Digital Display: step 4, image 2 of 3 Garmin STRIKER 4 Digital Display Replacement, Digital Display: step 4, image 3 of 3
      • Use the iFixit opening tool to gently lift the screen from the casing.
      Ask FixBot
2 other people completed this guide.
Author
with
Kylie Buchanan
106 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 92
All Time: 936
