Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Display Will Not Turn On
The display does not turn on and the view does not show anything.
Faulty Batteries
The most obvious and simplest symptom could be dead batteries. Consider replacing the batteries using this simple guide.
Battery Leads and Connections
If replacing the batteries does not work, check the battery leads and connections. The connections may have been corroded due to the batteries corroding. If this is the case, you can replace the battery leads and connections using this guide.
Screen Malfunction
If you know the camera is on, the screen itself is faulty. You can replace the screen using the simple guide.
Broken Battery Door
The battery door will not close. The door does not click into place.
Not Shut Completely
The door may not have closed completely due to improper insertion of the batteries that are pushing against the door. If this is not the issue, the latches may have snapped off. You can detach the door and replace it using this guide.
The Camera Won’t Turn On
The camera will not power up.
Battery Replacement
The batteries may be dead. You can refer to the Display Troubleshooting section on how to replace the batteries.
Power Button Replacement
The power button does not engage completely. Use this guide to replace the power button.
The Cameral Turns On But Does Not Show Anything
The LCD screen is showing a blue screen.
SD Card
There may not be a Storage Device (SD) card in the camera. Check to see if there is one in the camera.
Motherboard
If there is an SD card in the camera, the motherboard may be faulty. This guide will help you replace the motherboards.
Microphone Does Not Work
The microphone is not receiving any sound.
The Microphone is Blocked
Your hand could be covering the microphone on the side of the camera. Ensure the microphone is not being obstructed.
The Microphone is Faulty
If the microphone is not blocked, covered, or otherwise hindered, it most likely is broken. You can replace the microphone using this guide.
Device Page
Here is a link to the device page.
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 33
All Time: 772
