Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
No audio playback on videos
The device can record video, but does not seem to be recording any audio
Software crash
The software that controls the audio driver may have crashed. Restarting the device will run the software again. Sometimes the device just needs a reboot in order to function properly again.
Loose component
The microphone portion may have become loose inside the device or even damaged.
Frozen Screen
The camera powers on, but the screen is unresponsive or won't turn on.
Reset the Device
If your camera is on but unresponsive, hold down the power button for 10 seconds to restart the device.
Loose components
The screen component may have loosened from the mother board or maybe even damaged.
Device will not turn on
Device will not Power On nor looks like it is Functional
Power Button may be Stuck
Make sure that the Power Button is not stuck and if it is please refer to
Faulty batteries
Ensure that the batteries are fully charged or make sure that it is put in correctly. Make sure that you have the exact type of batteries, in this case double AA batteries and that they are facing in the correct directions indicated by the indications on the case.
Connections lost between Camera and Computer
Computer doesn't recognize the camera when plugged in
USB Connector on Laptop/PC
Make sure there is nothing inside the USB connector. Ensure that the inside is clean and if any dirt or debris is preventing a connection please remove carefully.
USB Port will not fit into PC
Sometimes the USB may not be functional or it may be very old. If its a very old USB drive please consider on buying a new one for the old one may corrupt the files.
USB component is loose from the Motherboard
The USB part of the camera may have lifted off the motherboard slightly, causing a severed connection. Please refer to this guide.
Conflicting devices plugged into computer
Some devices plugged into the computer cause others to become unrecognizable. Unplug any other USB device and try again.
Buttons are unresponsive
The buttons do not want to cooperate
Buttons may be Stuck
Check to make sure that none of the buttons are stuck and make sure that there isn't any sticky substance that got into the device. Fix the button using this guide.
Loose Buttons
Loose buttons are a common thing and it can happen some of the times. To fix a loose button refer to
Lost connection to mother board
The wire that connects the buttons to the mother board may have become loose or even damaged. Fix it by using this guide.
Author
with
Nathaniel Ruf
514 Reputation
5 Guides authored
UMass Dartmouth, Team 5-7, Martin Fall 2016 Member of UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 40
All Time: 4,405
