Flip Video Ultra USB connector Replacement
    1. Flip Video Ultra USB connector Replacement, USB connector: step 1, image 1 of 1
      • Unlock the battery cover by sliding the switch to the unlock position.
      Ask FixBot
    2. Flip Video Ultra USB connector Replacement: step 2, image 1 of 1
      • Remove the battery cover by sliding it down the camera.
      Ask FixBot
    3. Flip Video Ultra USB connector Replacement: step 3, image 1 of 1
      • Remove the batteries.
      Ask FixBot
    4. Flip Video Ultra USB connector Replacement: step 4, image 1 of 1
      • Slide the black upper casing off from the device.
      • This is a bit hard to get off, so don't be afraid to use a bit of force. There is no lock.
      Ask FixBot
    5. Flip Video Ultra USB connector Replacement: step 5, image 1 of 2 Flip Video Ultra USB connector Replacement: step 5, image 2 of 2
      • Remove the six 1mm screws from front of the camera with the Phillips Head screwdriver.
      Ask FixBot
    6. Flip Video Ultra USB connector Replacement: step 6, image 1 of 1
      • Remove the top casing from the bottom to reveal the inner circuit board.
      Ask FixBot
    7. Flip Video Ultra USB connector Replacement: step 7, image 1 of 2 Flip Video Ultra USB connector Replacement: step 7, image 2 of 2
      • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
      • Remove the six 1mm screws with the 1 Phillips head screwdriver.
      Ask FixBot
    8. Flip Video Ultra USB connector Replacement: step 8, image 1 of 2 Flip Video Ultra USB connector Replacement: step 8, image 2 of 2
      • Gently separate the circuit board from the casing.
      Ask FixBot
    9. Flip Video Ultra USB connector Replacement: step 9, image 1 of 2 Flip Video Ultra USB connector Replacement: step 9, image 2 of 2
      • Remove the three 1mm screws from the USB connector and back casing with the Phillips Head screwdriver.
      Ask FixBot
    10. Flip Video Ultra USB connector Replacement: step 10, image 1 of 2 Flip Video Ultra USB connector Replacement: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Gently lift the usb connector using the Plastic opening tool.
      • Using tweezers, remove the cord from the motherboard by gently lifting the connector.
      • The connector will be easier to remove if you wiggle the tweezers while lifting.
      Ask FixBot
    11. Flip Video Ultra USB connector Replacement: step 11, image 1 of 1
      • Fully remove the USB connector and replace it with the new USB connector.
      Ask FixBot
Nathaniel Ruf
514 Reputation
5 Guides authored
UMass Dartmouth, Team 5-7, Martin Fall 2016 Member of UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Members
60 Guides authored
2 Guide Comments
My USB port broke off so is there anyway I could save my videos that where om there
Corrina Guerrero - Reply Share
Where do you purchase the replacement usb connector?
DeEtte Moore - Reply Share
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 30
All Time: 1,607
