Up to 20% off select tools
Flip Video Ultra Power button Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
93
All Time:
1,097
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will walk you through on how to remove the power button and replace it. You will need the iFixit Opening Tool and the Phillips #1 Screwdriver. It should take no more than 15 minutes, if it takes more than that then you may have done something wrong.
    1. Flip Video Ultra Power button Replacement, Power button: step 1, image 1 of 1
      • Unlock the battery cover by sliding the switch to the unlock position.
      Ask FixBot
    2. Flip Video Ultra Power button Replacement: step 2, image 1 of 1
      • Remove the battery cover by sliding it down the camera.
      Ask FixBot
    3. Flip Video Ultra Power button Replacement: step 3, image 1 of 1
      • Remove the batteries
      Ask FixBot
    4. Flip Video Ultra Power button Replacement: step 4, image 1 of 1
      • Slide the black upper casing off from the device.
      Ask FixBot
    5. Flip Video Ultra Power button Replacement: step 5, image 1 of 2 Flip Video Ultra Power button Replacement: step 5, image 2 of 2
      • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
      Ask FixBot
    6. Flip Video Ultra Power button Replacement: step 6, image 1 of 1
      • Remove the top casing from the bottom to reveal the inner circuit board.
      Ask FixBot
    7. Flip Video Ultra Power button Replacement: step 7, image 1 of 2 Flip Video Ultra Power button Replacement: step 7, image 2 of 2
      • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
      • Remove the six 1mm screws with the 1 Phillips head screwdriver.
      Ask FixBot
    8. Flip Video Ultra Power button Replacement: step 8, image 1 of 1
      • Gently separate the circuit board from the casing.
      Ask FixBot
    9. Flip Video Ultra Power button Replacement: step 9, image 1 of 2 Flip Video Ultra Power button Replacement: step 9, image 2 of 2
      • Unscrew the single 1mm screw from USB housing unit.
      Ask FixBot
    10. Flip Video Ultra Power button Replacement: step 10, image 1 of 2 Flip Video Ultra Power button Replacement: step 10, image 2 of 2
      • Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
      Ask FixBot
    11. Flip Video Ultra Power button Replacement: step 11, image 1 of 1
      • Gently pry out the USB housing unit with the Ifxit Opening Tool.
      Ask FixBot
    12. Flip Video Ultra Power button Replacement: step 12, image 1 of 3 Flip Video Ultra Power button Replacement: step 12, image 2 of 3 Flip Video Ultra Power button Replacement: step 12, image 3 of 3
      • Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
      Ask FixBot
    13. Flip Video Ultra Power button Replacement: step 13, image 1 of 1
      • Unscrew the camera housing unit from the plastic case.
      Ask FixBot
Author
with
Nathaniel Ruf
514 Reputation
5 Guides authored
UMass Dartmouth, Team 5-7, Martin Fall 2016 Member of UMass Dartmouth, Team 5-7, Martin Fall 2016
UMASSD-MARTIN-F16S5G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 93
All Time: 1,097
