Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Device Experiences Pulsing Power
The device’s power cuts in and out.
Blocked Airway
The vacuum may have picked up something that didn’t reach the bin, it could be stuck in the brushbar, the shaft, or the bin inlet. Remove the tool, shaft, and bin inlet using this guide and remove any possible debris in each section.
Old Filter
The filter may be old and clogged. Remove the bin filter using this guide and test the device. If the device works properly with the filter removed, consider replacing the filter. Replace the filter using this guide.
Low Battery
The device may need to be charged as the battery may be low or depleted. The device typically needs to be charged for 3.5 hours. Check if the devices LED located on the base of the battery is flashing. If the light is flashing refer to The Device’s LED Flashes page.
The Device Rattles
The device rattles while in use.
Loose Tool Connection
The additional tools may have a loose connection to the shaft and motor.  Remove all tools and test vacuum.
Blocked Bin
Debris may be lodged or stuck in the Bin or Bin Inlet. Using this guide remove and empty the bin making sure there are no large pieces of debris lodged or stuck.
The Device Has No Power
The device will not turn on.
Low Battery
The device may need to be charged as the battery may be low or depleted. The device typically needs to be charged for 3.5 hours. Check if the devices LED located on the base of the battery is flashing. If the light is flashing refer to The Device’s LED Flashes page. If the power continues to fail due to the battery, you may need to replace it using this replacement guide.
Blocked Airway
There may be debris blocking key suction areas in the vacuum. Remove the tool, shaft, and bin using this guide while checking for and removing debris.
Dirty Filters
Either of the devices two filters may be clogged. Using the Intake Filter guide and Bin Filter guide, check to see if both filters are blocked. Clear away large debris and test device. If the device still has no power consider replacing the filters. Replace the appropriate filter by following the corresponding guides provided above.
The Device’s Brushbar Does not Rotate
The device’s brushbar fails to rotate when in use.
Loose Connection
The brush bar could be inserted wrong and causing the backup. Using this guide, try removing the brush bar and then reinsert the brush bar back in making sure to line up the grooves correctly.
Tangled or Jammed Brushbar
Debris may be caught on the brushbar preventing movement. Using this guide remove the brush bar and clean the bar of debris. Make sure no debris is left on the bar or the surrounding cleaner head to catch or tangle with debris when reinstalled.
Broken Brushbar
If your brushbar is visible broken or the steps above do not apply, you may need to replace the brushbar. You can use this replacement guide.
The Device Has Low Suction
The device’s suction power is too low.
Blocked Air Intake
Debris may have become lodged in the air intake. Remove the intake filter by following this replacement guide. Check the filter for debris clogging the filter. If needed, wash with water and let dry for 24 hours before replacing the filter.
Blocked Shaft
Debris may have become lodged in the shaft. Using part of this guide, remove the tool from the motor and check the shaft for debris. Test the device and if the device still has low suction refer to Blocked Air Intake or Blockage in Brushbar.
Debris may have become lodged in the brushbar, blocking the airflow. Using this guide check all the attachments you have on the vacuum for any blockages and remove them.
The light on the base of the battery starts flashing.
Blue Light Flashing
This light means that the vacuum battery is low. Charge your Dyson before using it again.
Fast Blue Light Flashing
This fast flashing means that the vacuum is experiencing no power or that there are blockages in the system. Refer to The Device Has No Power, The Device’s Brushbar Does not Rotate, or The Device Has Low Suction.
Amber Light Flashing
The amber light means there is no power because of temporary faults such as overheating or being in too low of temperatures. Stop using the vacuum and wait for it to cool or warm.
Red Light Flashing
The red flashing light means something more serious is wrong with your Dyson vacuum and that repair is needed. Contact Dyson Support to receive more information. 1 (844) 679-1647.
Author
with
AJ McLean-Scholz
888 Reputation
5 Guides authored
Cal Poly, Team S19-G1, White Winter 2020 Member of Cal Poly, Team S19-G1, White Winter 2020
CPSU-WHITE-W20S19G1
4 Members
60 Guides authored
15 Comments
What if you buy a brand new Dyson V8 Animal, finally get around to taking it out of the box, put it on the charger as is recommended, wait until all three blue lights turn off, try to push the trigger and you get NOTHING but a red light? What did I do wrong or what is wrong with it?
dlhmazda92 - Reply Share
turn on and vacuum works them by pass plug opens on top of filter and loose suction and will not pull thur the hose
i was using it on some small serriform beads and lost suction
primeguy - Reply Share
Help my dyson V8 will come on for 3 sec. Then stop . I have replaced the battery an the charger . I also changed the filters . Why is it doing this ? Help it’s less than a year old .
Cindy Rutledge - Reply Share
Power bar works intermittent, starts then stops… have to stop, lift off floor to get it to start again, works for under a minute then stops spinning again, not clogged, can’t figure out what the issue is!
Tammy - Reply Share
I charge my Dyson overnight but when I go to use it, it only last a for 30 seconds what should I do ,
And where can I buy spare parts?
liz08theavenue - Reply Share
Past 24 Hours: 11
Past 7 Days: 53
Past 30 Days: 267
All Time: 29,335
