Dyson V8 Animal Brush Bar Replacement
    1. Dyson V8 Animal Brush Bar  Replacement, Brush Bar: step 1, image 1 of 1
      • Push the red button and then slide the brush head off of the shaft.
      • The shaft must be held from moving when sliding the brush head off.
      Ask FixBot
    2. Dyson V8 Animal Brush Bar  Replacement: step 2, image 1 of 3 Dyson V8 Animal Brush Bar  Replacement: step 2, image 2 of 3 Dyson V8 Animal Brush Bar  Replacement: step 2, image 3 of 3
      • Insert a coin into the slot on the side of the brush head.
      • Turn the coin counter clock wise to unlock the brushbar.
      • Pull the brushbar straight out of the brush head.
      • Clean all debris off of the brushbar and from inside the brush head.
      • The brushbar will spring outwards slightly when unlocked successfully.
      Ask FixBot
4 other people completed this guide.
AJ McLean-Scholz
888 Reputation
5 Guides authored
Cal Poly, Team S19-G1, White Winter 2020 Member of Cal Poly, Team S19-G1, White Winter 2020
CPSU-WHITE-W20S19G1
4 Members
60 Guides authored
5 Guide Comments
Did that but brush still will not spin.
walt.florence - Reply Share
I can't remove the brush, it springs outwards but keep firmly attached to the "axis". I've also tried to remove the transparent cover, by removing all the screws I've found on it (6 in total) but seems impossible. Can anyone please post a step by step guide about how to dissemble the whole brush bar??
Henar Lanchas López - Reply Share
I’m saving my Pennys for the “coin tool”. It does seem hauntingly familiar however….
Enrico Crocetti - Reply Share
I am unable to insert a coin into the slot provided. No problem previously
Mgt trotter - Reply Share
Dyson V8 Animal - all of my 3 powered brushes will rotate freely, but will not power up. New battery, filters, cleaned all components and connections. Getting 21 volts at all connectors, but still no go.
M Daniels - Reply Share
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 95
All Time: 7,138
