Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Will Not Turn On
No matter what you do, you can't get your LabelManager to turn on.
Power button
Make sure to press and hold the power button to turn the device on.
Drained/bad battery
If your LabelManager won't turn on, you may have a drained battery. Simply charge or replace the battery pack.
Bad display
It is possible that nothing appears to be happening because the display is bad. If your LabelManager prints fine but you don’t see anything, it is possible the display is damaged and needs to be replaced. Click here to go to the replacement guide.
Label Will Not Print
No matter what you do, the labels won’t print.
Cassette isn’t properly inserted
If your LabelManager won’t print, make sure the label cassette is correctly inserted. Open the cartridge compartment and check the cassette.
Cassette is empty
If your LabelManager isn’t printing but the cassette is properly inserted, check label cassette to see if it is empty. If it is, the cassette needs to be replaced.
Cassette is jammed
Check label cassette to see if it is jammed. If it is, remove the jam by taking out the cassette and make sure the label passes smoothly before inserting.
Printhead is dirty
It is possible that the printhead is dirty and needs to be cleaned with a special brush that comes in the packaging or a cotton swab. Take it and brush off the dirt on the printhead.
Faulty Keys
The keys don’t seem to be working properly. The letters aren’t typing smoothly.
Something liquid substance spilled on it
The keys are sticking and needs to be replaced or thoroughly cleaned. Please follow this link to a guide for replacing the keyboard.
Letters are hard to press when trying to type
The keys take more force to push then it should and needs to be checked. The keys are most likely being obstructed or broken and needs to be looked into. Please follow this link to a guide for replacing the keyboard .
Software Will Not Install Properly
When you try to install the computer software, you receive an error message, or the software seems to install correctly but doesn’t function correctly.
You don’t have necessary system requirements
The system doesn't have the necessary requirements needed for the additional software. Check the website to find out which of the requirements your computer doesn’t have.
Software isn’t installed correctly
If the software installs but doesn’t function correctly, uninstall and reinstall the software again. If is still doesn't work, call tech support.
Label Not Cutting Correctly
When cutting the labels, it doesn’t come out straight.
Blade is dirty
Properly clean blade from time to time to maintain its good condition. You can use the brush provided in the device box.
Blade is broken
The blade could be chipped or dented. If this is the case then you might want to send the device back to the Dymo company where they would repair the cutter for you.
Author
with
Steven Nguyen
431 Reputation
3 Guides authored
USF Tampa, Team 6-5, Eyestone Spring 2016 Member of USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
3 Members
36 Guides authored
21 Comments
the label comes out black with light grey letters. It is as if the machine is printing in a negative image mode.
Richard Simmons - Reply Share
My machine won’t feed the paper, nothing is blocking it. The cartridge is brand new.
Alexandra Hawley - Reply Share
If I pull the label out as it’s printing it will work, but it won’t feed the paper on its own!
I put in the battery and it just flashes “flash".
Steven McConaughy - Reply Share
Does it need new firmware to be flashed to it, or perhaps it was accidentally put in a firmware flash mode?
David Greene - Reply Share
Past 24 Hours: 2
Past 7 Days: 30
Past 30 Days: 142
All Time: 32,951
