Up to 20% off select tools
Dymo LabelManager 280 Keyboard Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
97
All Time:
1,726
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 8 minutes
Difficulty: Moderate
Parts
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide leads you through the process of opening up the LabelManager and changing the keyboard. Keep in mind that the device has loose parts. Be careful and keep track of all parts.
    1. Dymo LabelManager 280 Keyboard Replacement, Rear Case: step 1, image 1 of 2 Dymo LabelManager 280 Keyboard Replacement, Rear Case: step 1, image 2 of 2
      • Remove battery.
      • Remove the label cassette.
      Ask FixBot
    2. Dymo LabelManager 280 Keyboard Replacement: step 2, image 1 of 2 Dymo LabelManager 280 Keyboard Replacement: step 2, image 2 of 2
      • Remove the two rubber feets
      • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
      Ask FixBot
    3. Dymo LabelManager 280 Keyboard Replacement: step 3, image 1 of 2 Dymo LabelManager 280 Keyboard Replacement: step 3, image 2 of 2
      • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
      • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
      Ask FixBot
    1. Dymo LabelManager 280 Keyboard Replacement, Keyboard: step 4, image 1 of 2 Dymo LabelManager 280 Keyboard Replacement, Keyboard: step 4, image 2 of 2
      • Remove the rubber keyboard.
      Ask FixBot
Author
with
Steven Nguyen
431 Reputation
3 Guides authored
USF Tampa, Team 6-5, Eyestone Spring 2016 Member of USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
3 Members
36 Guides authored
1 Guide Comment
thank god the bottom feet are not glued in. and the tabs are not difficult
Edward Wijntuin - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 97
All Time: 1,726
