Up to 20% off select tools
Dymo LabelManager 280 Screen Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
162
All Time:
5,343
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Dymo LabelManager 280 is an electronic label maker with a screen that previews the text before printing.
Please refer to the dymo and ifixit troubleshoot page before confirming the screen must be replaced.
The screen may need to be removed if the screen display is blank or damaged. This guide will help how to safely remove the display on the Dymo LabelManager 280.
    1. Dymo LabelManager 280 Screen Replacement, Rear Case: step 1, image 1 of 2 Dymo LabelManager 280 Screen Replacement, Rear Case: step 1, image 2 of 2
      • Remove battery.
      • Remove the label cassette.
      Ask FixBot
    2. Dymo LabelManager 280 Screen Replacement: step 2, image 1 of 2 Dymo LabelManager 280 Screen Replacement: step 2, image 2 of 2
      • Remove the two rubber feets
      • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
      Ask FixBot
    3. Dymo LabelManager 280 Screen Replacement: step 3, image 1 of 2 Dymo LabelManager 280 Screen Replacement: step 3, image 2 of 2
      • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
      • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
      Ask FixBot
    1. Dymo LabelManager 280 Screen Replacement, Screen: step 4, image 1 of 1
      • Further remove the 2 screws (1.2mm X 4mm Phillips #0 head).
      Ask FixBot
    2. Dymo LabelManager 280 Screen Replacement: step 5, image 1 of 2 Dymo LabelManager 280 Screen Replacement: step 5, image 2 of 2
      • Detach the ribbon cable.
      Ask FixBot
    3. Dymo LabelManager 280 Screen Replacement: step 6, image 1 of 1
      • Remove the screen.
      Ask FixBot
Author
with
Steven Nguyen
431 Reputation
3 Guides authored
USF Tampa, Team 6-5, Eyestone Spring 2016 Member of USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
3 Members
36 Guides authored
1 Guide Comment
Hi, thak you for the tutorial, it seems pretty simple. Do you know where to find the LCD screen, or whats the specs, maybe I can find it at AliExpress.
Jacques Maltais - Reply Share
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 162
All Time: 5,343
