Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The personal laptop will not turn on
Device does not power on.
Laptop has low power
There may not be a problem with the laptop, the battery could just be drained. Plug the laptop in to the charger. According to Dell, the battery should take about 2 hours to charge.
Battery is faulty
A Dell laptop battery will begin to show a noticeably shorter run time after 18-24 months of use according to Dell. Plug the laptop into a charger that works. If the laptop does not charge, this is a sign of a faulty battery and the battery needs to be replaced. Replace the battery using this guide.
Charger is faulty
When a Dell laptop charging cable is plugged in, a blue light will turn on. Ensure that the power adaptor is fully plugged in. If this light is not on and the adapter is fully inserted, this is a sign of a faulty charging cable. A new charging cable should be purchased.
Laptop has slow loading times/crashes often during use
RAM is near/at maximum capacity
If the computer suddenly starts running slowly while loading or running a program, close all unnecessary programs and windows, as that uses needed RAM space.
RAM is damaged/unsecured
Check the RAM card. If it appears damaged, it needs to be replaced. If it is unsecured, tighten it into place with a screwdriver.
(insert link here)
The screen has strange or distorted graphics
Unusual images appear on the screen.
Graphics card may be damaged
If the screen displays strange or distorted images, has unusual color variations or hazy "static" on the screen, the graphics card may be malfunctioning or damaged. The graphics card may need to be replaced.
Possible system overheating
Overheating will be the most noticeable after rendering 3D models for a long time. The fan may sound louder than usual. If this happens, remove the graphics card and clean it using compressed air.
Graphics card may not be secured
If the graphics card seems loose or not fully seated in the slot, ensure that they are screwed in tightly. If this doesn't fix the problem, the card should be replaced.
Computer powers on, but turns off immediately
The device turns off after you power it on.
Age of the CPU
When a computer turn off immediately after you power it on, it usually has a really old CPU that limits the computer and you must replace it with a new CPU.
(insert link here)
Overclocking of the CPU
Overclocking means making your CPU run faster . It will cause the CPU to increase the voltage, and will gradually damage the CPU by heat generated from the voltage, which means it will reduce the CPU's lifespan. Reduce the setting of the CPU to run slower, ideally to the standard official speed rating.
The screen is completely blank
Screen does not display images.
Display is disabled
The screen may have been accidentally disabled. It can usually be enabled by holding down the Fn key, to the left of the spacebar, and pushing the F5 key.
LCD damage
This is liquid crystal display. Check for physical damage to the screen. If there’s no screen damage, plug an external monitor into the laptop, and, if there’s images on the external monitor, there is probably damage to the LCD panel. This panel should be replaced. Replace the LCD screen using this guide.
The keyboard has stopped working
Keyboard does not register typing.
Keyboard is faulty
The Dell Laptop’s existing keyboard driver may be outdated. To solve the issue, try restarting the computer by removing the battery and holding down the power button for 12 seconds. When it restarts, the driver will should be restarted. If this still doesn’t work, you must then connect your laptop to an external keyboard and test it. If the external keyboard is working, then the keys are the main issue.
Missing keys
The key’s hinges may have been damaged which have caused them to be misplaced. They are located under each key and look similar to a plastic clip. You must look up your hinge style and replace it with a new one.
Keys are stuck
A Dell laptop keyboard will begin to jam after crumbs have been inside the keyboard. To check for crumbs inside the keyboard, face the keyboard down and gently shake the keyboard. You should also blow into the keyboard, this will remove any dust that’s causing the keys to jam.
The battery will not hold charge
Battery does not maintain a charge.
Battery is faulty
When a Dell Laptop battery is damaged, while charging it you will see a bright amber light flashing with a blue light. This means that there's a battery failure and you must purchase a new battery with an adapter. Replace the battery using this guide.
Battery is incompatible
There may not be a problem with the laptop, the BIOS system is outdated. Power off the laptop and then turn it on again. Once the Dell home screen pops up, repeatedly tap “F2”. This will bring you to the BIOS default settings. From there you can update the BIOS system.
CPU is overused
The entire cooling system of the Dell Laptop needs to replaced. Once the cooling system begins to slow down, it affects the CPU. A new cooling system should be purchased.
The laptop is unable to connect to the internet
The device does not permit the access to the internet.
WiFi is not enabled
Sometimes the WiFi is deactivated by the Operating System (OS). In order to enable it, perform the following steps:
- Search and click on Control Panel in the start menu
- Make sure that Categories is selected in the arrow menu next to the text View by at the top right corner
- Under the heading Network and Sharing Center, select View Network Status and Tasks
- On the left side of the window, select Change Adapter Settings
- Right click on the WiFi (or Wireless Network Connection) icon
- Lastly, click on Enable
Modem/router faulty
If you cannot get onto the internet, you may want to check your modem/router. It might be faulty. To fix it, power off and then turn back on the modem/router. Determine if the internet is enabled. If this happens to not be the case, a replacement will be needed. Contact your internet provider for a new one.
Signal obstructed
When there are object obstructing the path of the WiFi signals, the connection may be loss. To avoid this, make sure that there is a clear path between you device and modem/router.
Computer Is Very Hot
The computer is hot to the touch on the bottom.
Fan is Spinning But My Computer is Still Hot
A number of viruses and spyware will cause extreme strain on your CPU. Your fan will not be able to move fast enough to cool down your strained device. In this event, you should contact your local computer repair business so that you can free your system of the various amounts of spyware that could be causing it to overheat. In the event that air has stopped flowing, your cooling fan must be replaced. Consult our easy to follow replacement guide here.
Fan is Not Running or Running Slowly
The first thing you need to do is check and see if your fan is running. If it is, you should feel and hear air blowing through your exhaust vent. One of the main reasons why your fan is not running or running slowly is the buildup of dust and other debris around the fan, motherboard, as well as other internal components of the laptop. In this event, you can follow our disassembly guide [here]. You should follow the step up until the point of fan removal, once you have reached this step, you can easily clean the inner components with a soft microfiber cloth. Reassemble your computer and let it run for at least a half an hour. In the event that the computer continues to overheat, your fan must be replaced. Follow our replacement guide Dell Latitude E6420 Fan Replacement to do so.
CD/DVD Drive Malfunction
The disc tray will not move in/out of the laptop or the drive will not read discs.
CD/DVD Drive Will Not Eject
The motors that force the drive in and out are not functioning. The first thing to try is to eject the drive within the computer’s applications. You can usually right click on the CD/DVD drive in the “My Computer” section and click the eject option. If that does not work, the best option is to force eject the drive. There is a larger button on the Dell Latitude E6420 to the right of the eject button on the CD/DVD Drive. Clicking this button will unlock the whole drive and it can be easily slid out of the socket by pulling lightly.
CD/DVD Does Not Recognize Discs
The CD/DVD will not boot up a disc inserted. Refer to the troubleshooting page on the Dell support website linked here. https://www.dell.com/support/article/us/... Another problem that might be causing this is that your disc is damaged or has not properly been cleaned. Remove your disc and gently clean your disc with a soft microfiber cloth. Reinsert your disc and allow it time your computer to process the disk. If this does not work, your best option is to replace the CD/DVD drive. You can do this by following our replacement guide Dell Latitude E6420 CD/DVD Drive Replacement
5 Comments
Dell e6420 has windows 10 installed but there is no sound. Volume control is at 100 %.
Richard L. Marshall - Reply Share
My r6430 won't come at all. The power button will light and other keys will light up then you will hear the engine running then shut completely off
Mary Phillips - Reply Share
Hi sir my laptop is power on but not properly start. I tried to Windows installed but i couldn’t. What i do now sir
আমাদের কথা - Reply Share
tengo el mismo problema tiene Windows 10, pero no tiene sonido, pongo unos parlantes o audifonos que conecto y funcionan, en la prueba de testeo el parlante funciona, pero en sistema no toca nada.
Jhojan Villa Quispe - Reply Share
Battery timing problem
Atif malik Malik - Reply Share
