Dell Latitude E6420 Screen Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
29
Past 30 Days:
107
All Time:
5,065
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Laptop screens can crack or stop displaying picture. This guide will show users how to replace the screen.
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. Dell Latitude E6420 Screen Replacement, Battery: step 1, image 1 of 2 Dell Latitude E6420 Screen Replacement, Battery: step 1, image 2 of 2
      • Push the tabs on the left and right of the battery out towards the edge of the case.
      Ask FixBot
    2. Dell Latitude E6420 Screen Replacement: step 2, image 1 of 1
      • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
      Ask FixBot
    1. Dell Latitude E6420 Screen Replacement, Screen: step 3, image 1 of 2 Dell Latitude E6420 Screen Replacement, Screen: step 3, image 2 of 2
      • Open the laptop and lay it flat on your work surface.
      • Using the spudger, lift the bezel up from around the laptop screen.
      Ask FixBot
    2. Dell Latitude E6420 Screen Replacement: step 4, image 1 of 3 Dell Latitude E6420 Screen Replacement: step 4, image 2 of 3 Dell Latitude E6420 Screen Replacement: step 4, image 3 of 3
      • Using the screwdriver, remove four 5mm Phillips #0 screws from the bottom of the laptop screen.
      • Using the screwdriver, remove two 3mm Phillips #0 screws from the top of the laptop screen.
      • Lift the screen.
      Ask FixBot
    3. Dell Latitude E6420 Screen Replacement: step 5, image 1 of 1
      • Lift the laptop screen and flip it over to lay it on top of the keyboard.
      Ask FixBot
    4. Dell Latitude E6420 Screen Replacement: step 6, image 1 of 2 Dell Latitude E6420 Screen Replacement: step 6, image 2 of 2
      • Remove the piece of tape from the back of the LCD cable.
      Ask FixBot
    5. Dell Latitude E6420 Screen Replacement: step 7, image 1 of 2 Dell Latitude E6420 Screen Replacement: step 7, image 2 of 2
      • Lift the piece of tape attached to the LCD cable.
      • Once the tape has lifted, gently pull back to unplug the LCD cable.
      Ask FixBot
9 other people completed this guide.
Madysen Eames
1,555 Reputation
7 Guides authored
1 Guide Comment
Bonjour, Merci
endibos - Reply Share
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 107
All Time: 5,065
