Malfunctioning Display Screen
Screen is blank, blurry, or cutting in and out.
Improper Cable Connections
  • Make sure the computer/device connected to the monitor is on.
  • Make sure the monitor's power source is properly connected in the back and plugged in to an outlet.
  • Make sure the monitor is properly connected to the intended device via the VGA port. An adapter may be needed depending on the make of the device.
Screen Damage
  • Check for any visible screen damage (cracks, holes, etc).
  • See our Screen Guide.
Malfunctioning Power Button
Monitor does not turn on/off when the power button is depressed.
Bad Button
Circuitry
  • This may be due to an internal problem on the circuit board. A replacement board (located under the interface buttons) may be needed. See our Interface Buttons Guide to get to the circuit board.
Defective Pixels
Some pixels remain off or on. Stuck on pixels will remain a single color. Dead pixels will display no color.
  • Determine locations of the faulty pixels. This can be achieved by changing the image displayed on your screen and noting the lack of change from a pixel/pixels.
  • Turn off the monitor.
  • Gently massage the screen at noted locations.
  • Turn the monitor back on to see if there is any change.
  • If no change, you may need to replace the screen. See our Screen Guide.
Dim/Bright Display
Picture too dim or too bright.
Brightness of the Display
  • Reset monitor.
  • Push "Auto-Adjust" Button.
  • Select "Brightness" and adjust accordingly.
Inverter Failure
This requires a replacement to be done. See our Inverter Guide.
Misaligned Display
Image on screen is off-center or cut-off.
Monitor Settings
If the problem is due to the monitor, follow these steps:
  • Select "Centering" and adjust accordingly.
  • If problem persists, see Computer Settings.
Computer Settings
  • Adjust Resolution settings in Control Panel/System Settings.
Author
with
Mackenzie Keane
523 Reputation
5 Guides authored
Cal Poly, Team 5-36, Amido Fall 2011 Member of Cal Poly, Team 5-36, Amido Fall 2011
CPSU-AMIDO-F11S5G36
4 Members
72 Guides authored
2 Comments
my issue is not listed- when the computer boots up the display turns on for a split second then goes away. Pressing the on/off button and then back on brings the screen up for just a second and then it goes out again. Attached it to a desktop and another laptop- same results. Suggestions???
Eric Ferguson - Reply Share
My E193FPc display turns on when my computer starts, but then goes out. Pressing the off button and then pressing it on again, brings the display up for a split second then it goes out again. I attached it to a desktop and two laptops and it did the same. Any suggestions?
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 41
All Time: 3,233
