Up to 20% off select tools
Dell E193FPc Screen Replacement
Views: 6.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
104
All Time:
6,311
Comments: 1
1 comment on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide if your screen is cracked or broken in some way.
    1. Dell E193FPc Screen Replacement, Stand: step 1, image 1 of 1
      • Lay the monitor screen-down so the back screws are exposed.
      • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
      Ask FixBot
    2. Dell E193FPc Screen Replacement: step 2, image 1 of 1
      • Gently lift and pull away the stand at a slight angle away from the monitor.
      Ask FixBot
    1. Dell E193FPc Screen Replacement, Display Bezel: step 3, image 1 of 2 Dell E193FPc Screen Replacement, Display Bezel: step 3, image 2 of 2
      • Locate the two holes on the bottom of the monitor.
      • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
      • This task is much easier if two people pry simultaneously at each hole.
      • Continue prying along the entire edge of the monitor.
      Ask FixBot
    2. Dell E193FPc Screen Replacement: step 4, image 1 of 2 Dell E193FPc Screen Replacement: step 4, image 2 of 2
      • When finished prying, the plastic will partially fall away from the rest of the monitor.
      • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
      • While holding the frames together, carefully flip the monitor over so it faces screen down.
      • Gently lift and remove remove the rear case from the monitor.
      Ask FixBot
    3. Dell E193FPc Screen Replacement: step 5, image 1 of 3 Dell E193FPc Screen Replacement: step 5, image 2 of 3 Dell E193FPc Screen Replacement: step 5, image 3 of 3
      • Locate the green interface button board.
      • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
      • Lift the monitor interior away from the front cover.
      Ask FixBot
    1. Dell E193FPc Screen Replacement, Inverter Board: step 6, image 1 of 3 Dell E193FPc Screen Replacement, Inverter Board: step 6, image 2 of 3 Dell E193FPc Screen Replacement, Inverter Board: step 6, image 3 of 3
      • With the monitor facing down, remove the two 5.81 mm Phillips #2 screws on the right side of the metal casing.
      • With the monitor still facing down, remove the two 5.81 mm Phillips #2 screws on the left side of the casing.
      • Do attempt to pull apart the casing. There are still wires holding the front and back together.
      Ask FixBot
    2. Dell E193FPc Screen Replacement: step 7, image 1 of 1
      • Using a 5 mm nut driver, unscrew the VGA port's mounting screws from the metal casing.
      Ask FixBot
    3. Dell E193FPc Screen Replacement: step 8, image 1 of 1
      • With the monitor facing down, gently lift the back case away from the rest of the monitor to expose the inverter board and mother board.
      • Recall that the casing is still held together by several wires. Do not attempt to fully remove the back casing.
      Ask FixBot
    4. Dell E193FPc Screen Replacement: step 9, image 1 of 2 Dell E193FPc Screen Replacement: step 9, image 2 of 2
      • The inverter board is the smaller board in the corner.
      • Remove the three 7.69 mm Phillips #2 screws from the inverter board.
      • Remove the two 7.69 mm Phillips #2 grounding screws from the wire with the black connector.
      • Gently pull the inverter board away from the case. Note that the board is still connected to several components by wires.
      Ask FixBot
    5. Dell E193FPc Screen Replacement: step 10, image 1 of 2 Dell E193FPc Screen Replacement: step 10, image 2 of 2
      • There is a wire connecting the motherboard to the inverter board. Squeeze both sides of the connector and pull to remove it from the socket.
      • There is another wire connecting the button board to the inverter board. Remove the second white wire connector.
      • A third wire connects the inverter board to the screen circuit board. Remove the black wire connector.
      • The inverter board can now be fully removed.
      Ask FixBot
    1. Dell E193FPc Screen Replacement, Motherboard: step 11, image 1 of 1
      • With the monitor facing down, remove the 5.84 mm Phillips #2 screw from the metal sheet.
      • You can now open the device up. Be careful, there are still wires attached to the motherboard.
      Ask FixBot
    2. Dell E193FPc Screen Replacement: step 12, image 1 of 1
      • With the monitor facing down, lift the back cover up and lay it face up, exposing the motherboard.
      • Remove the five 7.7 mm Phillips #2 screws from the motherboard.
      Ask FixBot
    3. Dell E193FPc Screen Replacement: step 13, image 1 of 2 Dell E193FPc Screen Replacement: step 13, image 2 of 2
      Tool used on this step:
      Buy
      • Squeeze the plastic prong in the middle of the motherboard with a metal tweezer, while gently prying the other side with the plastic prying tool.
      • Be careful when using the metal tweezers. Make sure you do not make contact with any part that contains metal, for it may still have a charge. Discharge all capacitors.
      • This is easiest when the monitor is positioned such that motherboard is beneath the metal casing.
      Ask FixBot
    4. Dell E193FPc Screen Replacement: step 14, image 1 of 2 Dell E193FPc Screen Replacement: step 14, image 2 of 2
      • Remove the connector to the power outlet from the motherboard.
      • Remove the 4 connectors to the metal casing from the motherboard.
      • The motherboard can now be fully removed from the casing.
      Ask FixBot
    1. Dell E193FPc Screen Replacement, Screen: step 15, image 1 of 1
      • Remove the three 5.44 mm Phillips #00 screws on each side of the front of the metal casing.
      Ask FixBot
    2. Dell E193FPc Screen Replacement: step 16, image 1 of 3 Dell E193FPc Screen Replacement: step 16, image 2 of 3 Dell E193FPc Screen Replacement: step 16, image 3 of 3
      • Remove the three 3.94 mm Phillips #00 screws from the metal sheet along the front metal casing.
      • Gently pry the metal sheet away from the metal casing and lift off the metal piece.
      Ask FixBot
    3. Dell E193FPc Screen Replacement: step 17, image 1 of 1
      • Use a spudger to pry the screen casing away from the metal casing.
      Ask FixBot
    4. Dell E193FPc Screen Replacement: step 18, image 1 of 1
      • Gently pry the screen away from the metal casing.
      • The circuit board will still be connected to the metal casing. Do not rip out the screen to avoid damage to the board.
      Ask FixBot
    5. Dell E193FPc Screen Replacement: step 19, image 1 of 1
      • Squeeze the connector and remove the circuit board from the metal casing connector.
      • Use both hands to remove the circuit board. The screen is attached to the circuit board, so do not pull by the screen.
      Ask FixBot
5 other people completed this guide.
Author
with
Mackenzie Keane
523 Reputation
5 Guides authored
Cal Poly, Team 5-36, Amido Fall 2011 Member of Cal Poly, Team 5-36, Amido Fall 2011
CPSU-AMIDO-F11S5G36
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 104
All Time: 6,311
