Up to 20% off select tools
Dell E193FPc Interface Buttons Replacement
Views: 3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
98
All Time:
2,991
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Replace the interface buttons if they have fallen out or are worn out from usage.
    1. Dell E193FPc Interface Buttons Replacement, Stand: step 1, image 1 of 1
      • Lay the monitor screen-down so the back screws are exposed.
      • Remove the four 11.9 mm Phillips #2 screws securing the stand to the back of the monitor.
      Ask FixBot
    2. Dell E193FPc Interface Buttons Replacement: step 2, image 1 of 1
      • Gently lift and pull away the stand at a slight angle away from the monitor.
      Ask FixBot
    1. Dell E193FPc Interface Buttons Replacement, Display Bezel: step 3, image 1 of 2 Dell E193FPc Interface Buttons Replacement, Display Bezel: step 3, image 2 of 2
      • Locate the two holes on the bottom of the monitor.
      • Insert a plastic opening tool or spudger into the holes and gently pry the plastic apart along the groove.
      • This task is much easier if two people pry simultaneously at each hole.
      • Continue prying along the entire edge of the monitor.
      Ask FixBot
    2. Dell E193FPc Interface Buttons Replacement: step 4, image 1 of 2 Dell E193FPc Interface Buttons Replacement: step 4, image 2 of 2
      • When finished prying, the plastic will partially fall away from the rest of the monitor.
      • Do not try to fully remove the front frame yet. The frame is still attached to the buttons.
      • While holding the frames together, carefully flip the monitor over so it faces screen down.
      • Gently lift and remove remove the rear case from the monitor.
      Ask FixBot
    3. Dell E193FPc Interface Buttons Replacement: step 5, image 1 of 3 Dell E193FPc Interface Buttons Replacement: step 5, image 2 of 3 Dell E193FPc Interface Buttons Replacement: step 5, image 3 of 3
      • Locate the green interface button board.
      • Remove the three 9.71 mm Phillips #2 screws holding the interface button board to the display bezel.
      • Lift the monitor interior away from the front cover.
      Ask FixBot
    1. Dell E193FPc Interface Buttons Replacement, Interface Buttons: step 6, image 1 of 1
      • Behind the front panel of the plastic cover lies the button strip.
      • Remove the buttons by gently pulling up on the strip.
      • You may have to pry the plastic strip up with a prying tool or spudger to remove it.
      Ask FixBot
Author
with
Charley Grove
101 Reputation
1 Guide authored
Cal Poly, Team 5-36, Amido Fall 2011 Member of Cal Poly, Team 5-36, Amido Fall 2011
CPSU-AMIDO-F11S5G36
4 Members
72 Guides authored
1 Guide Comment
and then…?! you cant buy replacement buttons!! so now what?!
Sarah Barnes - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 98
All Time: 2,991
