Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Battery is Not Charging
Your battery will not charge or will not hold a charge
Charger is not plugged in
Find an electrical outlet nearby and plug the battery charger in with the battery attached. The light on the front panel will blink red if it is charging.
Old Battery
Over time, a battery deteriorates and loses its ability to hold a charge. You will need to purchase a new battery if your battery is old.
Blown Fuses
The fuse in the battery charger may have blown due to a power surge. It must be replaced. Check out our replacement guide for replacing the fuse.
Defective Battery Charger
The charger may not be charging the battery efficiently at all due to other broken parts or wear and tear. You will need to purchase a replacement battery charger.
Drill Won't Operate
Your drill will not work when the trigger is depressed.
Low/Dead Batteries
Your battery may by low on power or out of power. If the battery is low on power, the drill may work slowly or not at all. To replace the battery, check out our replacement guide.
Faulty Battery
First, check to see if the battery needs charging. If it is fully charged, but does not hold the charge for long while using the drill , you may need to purchase a replacement battery.
The battery charger may not be working. See the "Defective Battery Charger" section above for how to test the charger's functionality. If it does not work, you may need to purchase a replacement battery charger.
Corroded Brushes
The brushed that are attached to the motor may be old or have accumulated dirt. They may need to be replaced.
The Motor is Burned Out
The motor is the main source of power for your drill. If it is not working, then the drill will not either. To replace the motor, check out our replacement guide.
The Motor Connections are Dirty
The connections to the motor may be dirty. Clean them with a clean cloth.
Chuck is Wobbling
When operating the drill, the chuck is wobbling.
The Chuck is Loose
The chuck is a specialized clamp that holds the drill bit in place to ensure smooth drilling. It is the spinning black piece located directly behind where the drill bit is inserted. The chuck will wobble if it is not fully tightened. To fix this, rotate the chuck clockwise until the wobbling stops.
The Chuck is Defective
Build up could be blocking the chuck from being able to fully tighten. Remove the chuck and clean any build up. You may need to replace the chuck.
The Chuck is Corroded
Corrosion may have built up inside of the chuck. The chuck must be replaced.
Gears Making a Squeaky Noise
The gears are making a squeaky noise while the drill is operating
The Clutch is Broken
The clutch of the drill is located directly above the reverse switch and allows you to control the amount of torque being applied to a screw so it doesn’t go in too deep. So if your drill gears are making a loud noise or any noise that does not sound normal when it is rotating it may help to take the clutch off and see if it is broken. To replace the clutch, check out our replacement guide.
Drill is Stuck in Reverse
The drill will only drill in the reverse direction.
The Directional Switch is Engaged in the Reverse Position
There is a switch located just above the trigger that makes the drill switch directions when pressed. Switch it to the opposite position and see if this causes the drill to go forwards again,
The Area around the Reverse Switch is Dirty
Dirt and grime build up may cause the reverse switch to become stuck in the reverse position. Clean the area around the reverse switch.
The Reverse Switch is Broken
You may need to replace the reverse switch. Check out our replacement guide for replacing the switch.
Author
with
jake
324 Reputation
2 Guides authored
11 Comments
My DeWalt 970 has a trigger stuck in the forward position it will only stop turning when I remove the battery how do I release the trigger
Larry Fellenger - Reply Share
My dewalt dcd985 hammer drill/driver came back from the shop with reversed forward/reverse functions. Not a huge deal but I wanted to fix it today. I tried switching the wires to the brushes, that did not do anything. I am wondering about the wires coming off the switch if they are on the wrong poles, or the switch itself is bad/reversed. Any idea how to fix this?
Robert D Veldkamp - Reply Share
Can not take end drill out , what should I do?
nick061265 - Reply Share
gears on my drill making a rattling noise when I let go off the start trigger .sounds like they falling apart .
tony.crookham - Reply Share
I cannot get the battery to release? I press the release button and pull up but it is completely stuck - any ideas??
Karen Cochran - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 58
All Time: 33,487
