Unable to Play Videos
Playing a video makes the screen go black
Video Resolution is too High
Most likely the resolution is not compatible with the Creative Ziio tablet. The highest resolution that the tablet can play is 720p. Thus, try a video that has a lower resolution.
Touchscreen does not Respond
Touching the navigation buttons and touchscreen does not work
Reset the Tablet
Press the power button for ten seconds or until the screen goes black. Then, turn the device back on. This should alleviate the problem.
Device doesn't Charge
The device won't turn on, and the device won't respond to being charged
There May be Something Lodged in the Jack
First check if there is anything stuck in the 5V charging jack. Something may be blocking the electrical connection between your Ziio tablet and the charging cable plug.
Issue with the Cable
If that does not work then check the charging cable itself. To do this you can try charging the tablet with another 5V cable. If the tablet charges with a different cable then you may need to replace your original charging cable.
Dead Battery
If your tablet still does not charge then it is likely you have a dead battery. See our repair guide for how to replace the battery.
SD Cards are not Recognized
The device will not respond when SD cards are inserted
Blockage in the Card Port
Check if there is anything stuck in the SD card port. Something may be blocking the tablet from reading the card.
Non-Compatible Card
Check to see if the card is compatible with the device. This should be specified on the instructions. If that is not the problem, check to make sure that there are actually files downloaded onto the card. The last resort is checking to see if other brands of microSD/SD cards can be read.
There is Water Damage
If the device gets water logged, refrain from turning the device on, this could cause the circuits to short. The device needs time to dry out. Our recommendation is to use rice. Grab a decently sized bowl, pour in enough uncooked rice to be able to completely submerge the Ziio 7 device. Leave for at least twelve hours, and if it still does not work, leave in the rice and continue to check back periodically. It is possible that your Ziio 7 may be a casualty, and hopefully you purchased a warranty.
Device Repair Guides
Here are the links to our repair guides:
Creative Ziio 7" Battery Replacement
Creative Ziio 7" Camera Replacement
Creative Ziio 7" Motherboard Replacement
Creative Ziio 7" LCD Screen Replacement
Creative Ziio 7" Left Speaker Replacement
Creative Ziio 7" Right Speaker Replacement
Author
with
Kyle
126 Reputation
2 Guides authored
Cal Poly, Team 14-10, Maness Spring 2013 Member of Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Members
84 Guides authored
0 Comments
Past 24 Hours: 11
Past 7 Days: 12
Past 30 Days: 24
All Time: 1,403
