Up to 20% off select tools
Creative Ziio 7" Battery Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
87
All Time:
1,604
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Creative Ziio 7" Battery Replacement, Back Panel: step 1, image 1 of 3 Creative Ziio 7" Battery Replacement, Back Panel: step 1, image 2 of 3 Creative Ziio 7" Battery Replacement, Back Panel: step 1, image 3 of 3
      • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
      • The volume control button and the top power button may fall out during this step.
      Ask FixBot
    1. Creative Ziio 7" Battery Replacement, Battery: step 2, image 1 of 3 Creative Ziio 7" Battery Replacement, Battery: step 2, image 2 of 3 Creative Ziio 7" Battery Replacement, Battery: step 2, image 3 of 3
      • Remove the copper plate covering the motherboard by desoldering the ten solder points so that the copper plate is free.
      • The last point is hidden by the soldering iron.
      • Remove the copper plate once all the solder points are undone.
      Ask FixBot
    2. Creative Ziio 7" Battery Replacement: step 3, image 1 of 2 Creative Ziio 7" Battery Replacement: step 3, image 2 of 2
      • Remove adhesive tape covering the three wires connected to the motherboard.
      • Desolder the solder points connecting the wires to the mother board.
      Ask FixBot
    3. Creative Ziio 7" Battery Replacement: step 4, image 1 of 2 Creative Ziio 7" Battery Replacement: step 4, image 2 of 2
      • With a spudger, pry the battery from the back of the LCD screen.
      • The battery is attached with double sided foam tape. When prying, the tape will probably not come apart easy. This will result in the tape tearing and leaving residue.
      Ask FixBot
    4. Creative Ziio 7" Battery Replacement: step 5, image 1 of 1
      • Remove old battery and dispose of it responsibly.
      Ask FixBot
Author
with
Bryce Simmons
150 Reputation
2 Guides authored
Cal Poly, Team 14-10, Maness Spring 2013 Member of Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 87
All Time: 1,604
