Creative Ziio 7" Right Speaker Replacement
    1. Creative Ziio 7" Right Speaker Replacement, Back Panel: step 1, image 1 of 3 Creative Ziio 7" Right Speaker Replacement, Back Panel: step 1, image 2 of 3 Creative Ziio 7" Right Speaker Replacement, Back Panel: step 1, image 3 of 3
      • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
      • The volume control button and the top power button may fall out during this step.
      Ask FixBot
    1. Creative Ziio 7" Right Speaker Replacement, Right Speaker: step 2, image 1 of 1
      • The right speaker is directly below the battery as shown.
      • Remove the two 4mm Phillips #00 screws found in the speaker at the bottom left corner of the device.
      Ask FixBot
    2. Creative Ziio 7" Right Speaker Replacement: step 3, image 1 of 2 Creative Ziio 7" Right Speaker Replacement: step 3, image 2 of 2
      • Once the screws are removed, discard the broken speaker.
      • Replace the broken speaker with a new right speaker.
      Ask FixBot
Bryce Simmons
150 Reputation
2 Guides authored
Cal Poly, Team 14-10, Maness Spring 2013 Member of Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 99
All Time: 594
