Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Unresponsive Cursor
The mouse is plugged into the computer, but will not move on the screen when the user gives input.
Drivers Not Installed
The Corsair Katar’s device drivers may not be installed properly, or may be out-of-date. To fix this, download the latest version of the Corsair Utility Engine (CUE) software. This can be found on Corsair’s website by searching for "Katar" on the Downloads Page. If the site asks you to sign up before downloading the file, just click on "Or skip this step and start Download" under the "Submit" button.
USB is Not Plugged In
Make sure the Corsair Katar is properly plugged into a USB port. When properly set up, the computer it’s plugged into will recognize the device.
Sensor is Blocked
The Corsair Katar has a sensor on the bottom of its shell that tracks mouse movement. It could be dirty and will not pick up movement until it’s cleaned. Use rubbing alcohol and a microfiber cloth to gently clean the sensor and remove any debris that may be covering it. If the issue persists, consult the following guide: Corsair Katar Optical Sensor Replacement
Incompatible Operating System
The Corsair Katar is only compatible with Windows 10, Windows 8, and Windows 7 operating systems.
Scroll Wheel Lagging / Unresponsive
Scroll wheel actions are delayed, or not working properly
Mouse Software is Not Up-To-Date
Make sure your mouse has the latest drivers installed. To ensure this, download the newest version of the Corsair Utility Engine (CUE) software. This can be found on Corsair’s website, by searching for “Katar” on the Downloads Page. If the site asks you to sign up before downloading the file, just click on "Or skip this step and start Download" under the "Submit" button.
Scroll Wheel is Dirty
Over time, dirt and grime can build up on and around the scroll wheel. This can result in delayed or unresponsive movement. Use compressed air to clean the scroll wheel.
Wheel Sensor is Dirty / Defective
It’s possible that dirt and grime have built up inside the mouse, on the wheel sensor itself. Try opening up the mouse and cleaning the wheel sensor. If that doesn’t solve the issue, you may have a defective sensor, which will need to be replaced. See the following guide for instructions: Corsair Katar Scroll Wheel Sensor Replacement.
Unresponsive Mouse Buttons
The left or right click button on the mouse is not responding to commands, or is hard to click.
Sticky Buttons
The mouse may be dirty and in need of cleaning. Use compressed air to clean under the mouse buttons.
Bad Connection Between Mouse and Computer
Make sure the mouse wire is plugged securely into the USB port. If this does not work, try cleaning the USB port by lightly rubbing it with a Q-Tip. You can also try restarting your computer or switching USB ports.
Broken Mouse Buttons
The DPI button or left and right click buttons inside the mouse may break after a long period of use. If the left or right buttons are broken, you will need to take apart the mouse and replace them. If your DPI button is not working, the issue may be with the sensor. Consult this guide for help: Corsair Katar DPI Sensor Replacement.
Mouse Not Gliding Properly
The mouse moves in a slow, dragging manner rather than gliding smoothly.
Improper Surface
The surface the mouse is on could be affecting the movement. Try different surfaces, such as paper or a mousepad, to see what works best.
Dirty Mouse Feet
The bottom of the mouse may be dirty. Try cleaning it with a Q-Tip or blowing compressed air to clean the surface and the cracks of the mouse.
Damaged Mouse Feet
The pads on the bottom of the mouse may have worn down. You can replace them by buying new skates to place over the old mouse feet.
Mouse Not Recognized By Computer
The mouse is plugged into the computer, but is not being recognized
Bad USB Port
The USB port that you plugged into may be faulty, or have out-of-date device drivers. Try another USB port first; if the device still isn’t recognized, update your computer’s USB drivers.
Mouse USB Cable Damaged / Defective
Inspect the Katar’s USB cable for damage. If it feels loose or has exposed wires, it will need to be fixed. It is also possible for it to be faulty, even though no damage is visible. For repair instructions, please consult the following guide: Corsair Katar USB Cable Replacement.
Author
with
Ryan Matesa
248 Reputation
1 Guide authored
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
3 Members
72 Guides authored
3 Comments
Where i can buy dpi sensor only? Because my katar cant change dpi only
Novan ardiansyah - Reply Share
Reset the mouse it will work
DARSHAN NASARE - Reply Share
what does it mean when you connect it to your computer but instead of blinking the colors RED, WHITE, GREEN, it blinks blue and randomly change to different colors.
Devil666 - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 63
All Time: 14,698
