Corsair Katar DPI Sensor Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
61
All Time:
842
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the DPI (dots per inch) sensor inside your Corsair Katar mouse is not operating correctly, this guide will show you how to replace it.
Tools
    1. Corsair Katar DPI Sensor Replacement, Corsair Katar Disassembly: step 1, image 1 of 2 Corsair Katar DPI Sensor Replacement, Corsair Katar Disassembly: step 1, image 2 of 2
      • Unplug your mouse before starting.
      • Flip the mouse over so the bottom is facing up.
      Ask FixBot
    2. Corsair Katar DPI Sensor Replacement: step 2, image 1 of 1
      • Remove the three skates on the bottom of the mouse using the plastic opening tools.
      • Skates will be very sticky.
      Ask FixBot
    3. Corsair Katar DPI Sensor Replacement: step 3, image 1 of 2 Corsair Katar DPI Sensor Replacement: step 3, image 2 of 2
      • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
      Ask FixBot
    4. Corsair Katar DPI Sensor Replacement: step 4, image 1 of 1
      • Detach the bottom of the mouse from the upper shell.
      • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
      • Use the plastic opening tool to detach the white DPI sensor cable from its port.
      • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
      Ask FixBot
    1. Corsair Katar DPI Sensor Replacement, DPI Sensor: step 5, image 1 of 2 Corsair Katar DPI Sensor Replacement, DPI Sensor: step 5, image 2 of 2
      • Use the JIS 0 screwdriver to remove the two 5mm screws holding the DPI sensor.
      Ask FixBot
    2. Corsair Katar DPI Sensor Replacement: step 6, image 1 of 1
      • Lift the DPI sensor away from the mouse shell.
      Ask FixBot
2 other people completed this guide.
Margaret Loughren
594 Reputation
5 Guides authored
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 61
All Time: 842
