Corsair Katar Scroll Wheel Sensor
  1. Corsair Katar Scroll Wheel Sensor, Corsair Katar Disassembly: step 1, image 1 of 2 Corsair Katar Scroll Wheel Sensor, Corsair Katar Disassembly: step 1, image 2 of 2
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
    Ask FixBot
  2. Corsair Katar Scroll Wheel Sensor: step 2, image 1 of 1
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
    Ask FixBot
  3. Corsair Katar Scroll Wheel Sensor: step 3, image 1 of 2 Corsair Katar Scroll Wheel Sensor: step 3, image 2 of 2
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
    Ask FixBot
  4. Corsair Katar Scroll Wheel Sensor: step 4, image 1 of 1
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
    Ask FixBot
  5. Corsair Katar Scroll Wheel Sensor, Scroll Wheel: step 5, image 1 of 2 Corsair Katar Scroll Wheel Sensor, Scroll Wheel: step 5, image 2 of 2
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
    Ask FixBot
  6. Corsair Katar Scroll Wheel Sensor: step 6, image 1 of 1
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
    Ask FixBot
  7. Corsair Katar Scroll Wheel Sensor: step 7, image 1 of 1
    • Push the scroll wheel to the right side of the motherboard as shown, then pull it away from the board to remove.
    Ask FixBot
  8. Corsair Katar Scroll Wheel Sensor, Scroll Wheel Sensor: step 8, image 1 of 2 Corsair Katar Scroll Wheel Sensor, Scroll Wheel Sensor: step 8, image 2 of 2
    • Flip the motherboard over and remove the clear plastic cover from the bottom of the board.
    Ask FixBot
  9. Corsair Katar Scroll Wheel Sensor: step 9, image 1 of 2 Corsair Katar Scroll Wheel Sensor: step 9, image 2 of 2
    • Desolder the 5 connecting pins to remove the scroll wheel sensor from the motherboard.
    Ask FixBot
2 other people completed this guide.
Margaret Loughren
594 Reputation
5 Guides authored
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
3 Members
13 Guides authored
2 Guide Comments
bonsoir moi ma molette tourne dans le vide rien ne accroche merci
Tara - Reply Share
Do I need new pads when I take out the old ones or will the same one stick?
Ishaan Patel - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 46
All Time: 2,267
