Hair Dryer Won't Turn On
When plugged in the hair dryer won't start
Broken On/Off Switch
Before attempting anything else, try switching the on/off button to on and holding it down for multiple seconds. The button may be loose or you may need to press it with more force. If that doesn't work, unplug the hair dryer and press the reset button, either on the plug or on the hair dryer, then plug it back into the outlet. If the button seems completely broken click here to see how you can fix it.
Faulty Power Cord
Make sure that the plug is connected to an outlet in your wall. Examine the cord for any exposed wires that could be preventing electricity from reaching the hair dryer.
Defective Outlet Reset Buttons
If there is no clear solution, the problem likely lies in the outlet plug. Try pushing the reset button on the hair dryer before turning it on. If that does not work, then the buttons might be broken and you will need to get a new hair dryer.
Little to No Air Comes Out
The air stream is not forceful
Blockage in the Airways
Examine the nozzle for any easily removable blockages. Check for hairs or dust caught in the back grill. If no air comes out after removing all visible clogs, try opening your hair dryer to find any clogs that weren't visible. Hair may be stuck in the air motor, check this guide to see how you can remove it.
On the Wrong Setting
Double check that the setting button is switched to the highest setting.
Clogged Fan
If none of the previous solutions are successful, it is likely that the fan of motor needs to be cleaned. You can check this guide to see how you can remove it.
Unable to Switch Between Settings
No response from pressed buttons
Resin Buildup Inside the Device
Resin or oil build up affects the button's ability to function properly. Use either a towel or better, compressed air, to clean around the buttons. Check here to see how you can clean the buttons and make sure they work properly.
Faulty Buttons
If resin and oil build up is not the problem, it is likely the button switchboard has malfunctioned. To fix this, the switches may need to be replaced. Depending on which button is not responding, use either the Cold Shot Button Replacement Guide, Hot/Cold Button Replacement Guide, or the On/Off Button Replacement Guide to restore the functionality of the buttons.
Only Cold Air Comes Out
Hot air doesn't come out of the hair dryer
Verify that the button has clicked to the hottest setting and not stuck on the cool setting.
Faulty Heating Element
If the setting is on "Hot" and still only produces cold air, it is likely that there is a problem with the heating system. The heating system will need to be replaced or a new hair dryer must be bought.
Hair Dryer Shuts Off By Itself
Hair dryer stops running and won't turn back on
Overheating
Using your hair dryer for more than 7-10 minutes can cause it to automatically shutdown. Unplug the device and let it cool down, preferably in a cool environment, for 2-3 minutes. Go back to normal use. The reset button may need to be pushed.
Hair Dryer is Scalding Hot
The hair dryer heats up to burning hot temperatures
Defective Heat Shield
If the hair dryer feels extremely hot to touch, the heat shield might be flawed and no longer insulating the heat coils in the hair dryer. Click here to check out how to replace it.
Zachary Shaieb
11 Reputation
0 Guides authored
Cal Poly, Team 10-58, Amido Spring 2014 Member of Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Members
84 Guides authored
5 Comments
If you have had your hair dryer more than 5 years is it time to replace it . As my hair dryer just shuts off . It dosnt come back on
marsh.kathy - Reply Share
I’ve had mine not even a month and it’s already overheating and shutting off. Can I get a replacement?
maxtess - Reply Share
I have mine a month and it just stopped turning on. Piece of crap. I won’t get another Conair.
Leonard Herman - Reply Share
Yup, mines a pos too and quit after 6 weeks of hardly any use
Amber alert - Reply Share
Muy bien explicado Pero quisiera hacerle una pregunta si el supresor que parece a un capacitador 129 69 hf 1,ama está inflado eso hace que no caliente la resistencia de Conair infinit pro
Hugo Izaguirre - Reply Share
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 112
All Time: 39,001
