Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Air Fryer is not turning on?
Power is not running through the device.
Faulty Power Adapter
Ensure the power adapter is plugged in to an outlet. If the device is not turning on, the adapter is faulty. Consider purchasing a replacement adapter.
Mismatch Power Outlet
The power adaptor might have two different power prongs’ size, it might not fit into the power outlet, therefore, purchase another power adaptor plug into the power outlet and uses that instead of the original power outlet.
Wall Outlet not Producing Power
Try a different outlet it’s possible that the outlet has a malfunctioning wire or somehow not receiving power.
The Fryer Basket is not Fitting Properly
You have trouble getting the fryer basket to fit in the fryer.
The Guiding Clips does not line up and snap into place in the side
When the fryer basket doesn't fit, typically one of the sides doesn't fit flush. Simply push the the side sticking out so it snaps in flush with the rest of the device.
There is Debris in the way
If the fryer basket isn't getting all the way in remove the basket and check to make sure there isn't something blocking it. Once you have made sure there is nothing in the way of the fryer basket try to put it back on again.
Broken Fryer Basket
If you put the fryer basket in and it does not snap into place and it feels loose, it might be broken. Take the basket out and inspect the basket clips and fryer clips located on the sides and bottom of where the basket goes in and make sure they aren't broken. If any of them are broken do not use the air fryer and look for replacement parts online. Even if it looks like nothing is broken but the basket does not snap into place you maybe want to get it replaced or have it inspected.
Smoke coming from Air Fryer
The air fryer is ventilating smoke at the top.
White Smoke is coming out of the Air Fryer
This is a common occurrence within Air Fryers. When you’re frying food that contains a lot of moist, steam will come out of the Air Fryer. People tend to identify steam as white smoke. Most of the time nothing is wrong.
Black Smoke is coming out of the Air Fryer
This means that your food contains high levels of fat. The fat then releases grease that burns on high temperature. To fix this issue, add water in the basket before frying the food. The excess fat will go into the water. This will be beneficial for both you and the Air Fryer because it will not only stop causing black smoke. It will also be easier to clean the basket after cooking.
Blue Smoke coming out of the Air Fryer
This is a very rare but serious problem. This is electrical smoke. This can not only be dangerous for the Air Fryer but for the person also. Blue smoke releases extreme amounts of toxins and can be lethal to breath. Unplug the Air Fryer immediately. Do not use this device until it’s repaired. If this device is unrepairable, consider buying a new Air Fryer for your safety.
The Timer has no sound when it’s finished?
When the food is finished the timer doesn’t make a sound.
Timer is not starting
Sometimes people can make mistakes such as turning on the temperature knob instead. Check out the timer and make sure it’s running.
Mechanical issues
There are times when the timer can get stuck which would prevent the timer to not fully end its cycle. To fix this issue, you should open up the air fryer take out the timer. Make sure nothing is stuck on it. You may need to wipe off the area. When you’re finished cleaning the area of the timer, attach the timer back into its position.
Faulty Timer
If the timer fails to respond, try replacing it.
The temperature knob is not activating?
Trying to adjust the desirable temperature but no change in temperature as result.
Faulty Temperature Knob
Check to see if the button on the top is indense; sometime while exploring the machine, you might put too much into pressing down the knob. Pry the knob out, clean-up the surrounded area and put it back into place by pressing it lightly down. If this does not solve the problem, follow this guide to replace the temperature knob.
Faulty Display Temperature Knob
On a certain machine, the numbers are not clearly stated on the knob, and sometimes can be confused with the timer knob.
Temperature Knob is Loose
With a simple movement, the temperature knob slide sideway making it move into another temperature degree. You would have to just tape it down, and prevent adjustment movement.
Author
with
Robert Gates
216 Reputation
1 Guide authored
UW Tacoma, Team S1-G4, Rose Fall 2018 Member of UW Tacoma, Team S1-G4, Rose Fall 2018
UWT-ROSE-F18S1G4
4 Members
36 Guides authored
40 Comments
Fan not working lite is on heat is working no fan help
Robert Buysman - Reply Share
My Chefman Air fryer Oven will not operate after completing a cooking cycle. It will have to “cool down” for a substantial amount of time before becoming operational again. I am forced to have my guests wait between batches! Is this normal?
Tonya - Reply Share
My rotisserie air fryer hasn’t worked since I purchased it. The fan will come on put no heat please help. Really need my air fryer
Jacqueline Andrews - Reply Share
Was cooking & it just stopped
please reply
amlrealestate - Reply Share
i got the chefman mulitfunction air fryer for two weeks now and now i plug it in hear the sound notifying that its on but the control panel isnt light up . but it will turn on and cook as normal just cant see the control panel.. please someone help thanks
irun logic - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 85
All Time: 35,647
