Chefman RJ38-V2-35 Timer Replacement
Views: 3K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
86
All Time:
3,037
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the air fryer is not stopping at an allotted time for cooking, this guide is for you. This guide will work you through how to replace the timing system in the air fryer. It’s a semi long process, but not too challenging.
Tools
    1. Chefman RJ38-V2-35 Timer Replacement, Timer: step 1, image 1 of 1
      • Using the plastic opening tool, pop off each of the four corners on the top silver plate.
      Ask FixBot
    2. Chefman RJ38-V2-35 Timer Replacement: step 2, image 1 of 1
      • Twist off the temperature knob.
      Ask FixBot
    3. Chefman RJ38-V2-35 Timer Replacement: step 3, image 1 of 2 Chefman RJ38-V2-35 Timer Replacement: step 3, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the four 4mm screws, one in each corner.
      • Also unscrew two 4mm screws.
      Ask FixBot
    4. Chefman RJ38-V2-35 Timer Replacement: step 4, image 1 of 2 Chefman RJ38-V2-35 Timer Replacement: step 4, image 2 of 2
      • Pull off top black cover.
      Ask FixBot
    5. Chefman RJ38-V2-35 Timer Replacement: step 5, image 1 of 3 Chefman RJ38-V2-35 Timer Replacement: step 5, image 2 of 3 Chefman RJ38-V2-35 Timer Replacement: step 5, image 3 of 3
      • Squeeze on plastic pieces holding timer down and push out.
      Ask FixBot
    6. Chefman RJ38-V2-35 Timer Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Pull cable from timer using either hands or tweezers.
      Ask FixBot
2 other people completed this guide.
Robert Gates
216 Reputation
1 Guide authored
UW Tacoma, Team S1-G4, Rose Fall 2018 Member of UW Tacoma, Team S1-G4, Rose Fall 2018
UWT-ROSE-F18S1G4
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 86
All Time: 3,037
