Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera does not turn on
Camera does not respond when pressing the power button
Battery is missing or placed incorrectly
Open the battery compartment door located on the bottom right of the camera. Check whether battery is there. If not, a battery is needed. If there is a battery, make sure that it is inserted correctly (the gold lining will match up with the terminals in the battery compartment).
Camera isn't charged
If the battery has died, the camera will not turn on. Remove the battery and attach it to the battery charger. Wait for the light to change to green indicating that it is fully charged, then reinsert back into the camera. (If you have no charger, you may connect the camera, with the battery inserted, to your computer using it's USB cable)
Charger is defective
If the battery is inserted in the charger, but the light indicating a charge does not come on, check to make sure the battery is inserted correctly in the charger. If it is, then the charger may be bad. Try using a different charger.
Battery is defective
If the battery still does not charge with a new charger, then the battery may be bad. Purchase or use a new battery.
Lens does not fully extend or retract
Whenever you turn your camera on or off, the lens piece becomes stuck half-way
There is a misfire somewhere in the mechanics
Sometimes, the camera will not function correctly due to a random electrical short within the camera itself. With the power off, remove the battery, and let the camera sit for around an hour. Reinsert the battery and turn the camera back on.
Dirt is stuck in the lens
With the camera turned off, insert a thin piece of paper inside the opening of the lens and slide it around to dislodge any loose material. Turn the camera back on. The lens should fully extend. You may also use a can of condensed air or simply blow into the cracks.
The battery cover is open
If the battery cover is opened during the camera’s power up, the camera may go into a power save mode and quit all functions. Turn the camera off, ensure the cover is closed snugly, and turn the camera back on.
The camera was dropped with the lens open
Such a drop could shake the connections to the lens piece loose, or damage them. Disassemble the camera following our guide until you have reached the lens component. Ensure all connections are secure and not damaged. Reassemble the camera and attempt to restart it.
The lens motor is faulty or has died
Following the previous instructions, disassemble the camera and inspect the connections. If everything is still connected and unharmed, it is most likely the motor that runs the lens that has been damaged. You can find a guide on how to replace the motor here.
Back display will not come on
The camera is turned on, and the lens is out, but the screen is still black
The display has been turned off
Sometimes the display screen will accidentally become turned off. With the camera turned on, try pressing the DISP button near the bottom of the camera several times to see if the display will reappear.
The screen is disconnected
If the screen does not turn back on after using the DISP button, it may have become disconnected. Follow this guide to disassemble the camera until you reach the display screen and it's connections. Ensure all connections are secure and intact.
The screen is broken
If the connections are bad, or damaged, or if the screen itself is broken, it will need to be replaced. Our guide will walk you through how to do that.
Flash does not work
Flash does not turn on when I am trying to take a picture
Flash is turned off
After you turn the camera on, move the flash switch on the left side of the camera to raise the flash. Press the flash button (lightning bolt) and select ‘on’, when the flash icon is displayed on the monitor the setting is complete.
Spring mechanism is broken
If you have depressed the flash button, but the flash bulb does not pop up, the internal spring mechanism has become faulty or broken.
The battery is low on charge
Make sure that the camera is charged. If the battery is low the flash will not work. Remove the battery and place it in the wall charger. Plug the charger into the wall and wait until the battery is fully recharged (the indicator light will be green).
The flash bulb is dead or broken
The flash has died or become faulty. Follow our guide here on how to replace it.
Images are blurry or out of focus
Your photos are fuzzy or hard to see
Front lens is unclean or covered
Using a soft rag, wipe the exposed glass of the lens, then inspect to ensure the lens is clean.
Photo was taken before camera was able to focus
Ensure that your camera has had time to fully focus on the object you are attempting to photograph. Hold the shutter button down half-way and wait for the image on the display screen to appear clear and in focus.
Lens is distorted or broken
Remove the existing lens unit and replace with a new one following our guide above.
Jennyfer Munoz
441 Reputation
3 Guides authored
USF Tampa, Team S6-G4, Lacy Spring 2017 Member of USF Tampa, Team S6-G4, Lacy Spring 2017
USFT-LACY-S17S6G4
3 Members
72 Guides authored
6 Comments
only top half of lens cover is in place, bottom half seems to be jammed open
tfarr - Reply Share
After shooting a picture a signal of “Busy” comes up and it takes too long until I am able to shoot the next picture. Have I put on a wrong setting?
chouvarda - Reply Share
Sx620 hs
Autofocus goes to just about perfect and then JUST as it gets it … it immediately slices back to fairly out of focus and stays there as shot is taken. The problem may not be as great when lighting is bright and contrast in image is high. It is also a problem that seems to have appeared rather suddenly.
Any thoughts?
Michael J. McFadden - Reply Share
The red video button is not showing it’s on or not on the screen
TM-Butterflies - Reply Share
The green light flashes and beeps and lens extends out but nothing else happens
David Burke - Reply Share
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 91
All Time: 7,901
