Canon PowerShot SX600 HS Flash Assembly Replacement
    1. Canon PowerShot SX600 HS Flash Assembly Replacement, Battery: step 1, image 1 of 1
      • To remove the battery, locate the battery cover on the bottom of the camera.
      • Using your thumb, press down on the cover and slide it outwards.
      Ask FixBot
    2. Canon PowerShot SX600 HS Flash Assembly Replacement: step 2, image 1 of 1
      • Depress the orange lever holding the battery in place to unlock it.
      Ask FixBot
    3. Canon PowerShot SX600 HS Flash Assembly Replacement: step 3, image 1 of 2 Canon PowerShot SX600 HS Flash Assembly Replacement: step 3, image 2 of 2
      • Use your fingers to remove the battery.
      • Be sure to remember the alignment of the nodes for reassembly.
      Ask FixBot
    1. Canon PowerShot SX600 HS Flash Assembly Replacement, Power and Shutter Buttons: step 4, image 1 of 1
      • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
      Ask FixBot
    2. Canon PowerShot SX600 HS Flash Assembly Replacement: step 5, image 1 of 1
      • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
      Ask FixBot
    3. Canon PowerShot SX600 HS Flash Assembly Replacement: step 6, image 1 of 1
      • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
      Ask FixBot
    4. Canon PowerShot SX600 HS Flash Assembly Replacement: step 7, image 1 of 2 Canon PowerShot SX600 HS Flash Assembly Replacement: step 7, image 2 of 2
      • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
      Ask FixBot
    5. Canon PowerShot SX600 HS Flash Assembly Replacement: step 8, image 1 of 1
      • Use an opening tool to gently remove the power and shutter button assembly from the frame.
      Ask FixBot
    1. Canon PowerShot SX600 HS Flash Assembly Replacement, Display Screen: step 9, image 1 of 2 Canon PowerShot SX600 HS Flash Assembly Replacement, Display Screen: step 9, image 2 of 2
      • Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
      Ask FixBot
    2. Canon PowerShot SX600 HS Flash Assembly Replacement: step 10, image 1 of 1
      • Use a Phillips #000 screwdriver to unscrew the 4mm screw.
      Ask FixBot
    3. Canon PowerShot SX600 HS Flash Assembly Replacement: step 11, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the no-fuss connector from its holder.
      Ask FixBot
    4. Canon PowerShot SX600 HS Flash Assembly Replacement: step 12, image 1 of 1
      • Gently lift the protector from the frame.
      Ask FixBot
    5. Canon PowerShot SX600 HS Flash Assembly Replacement: step 13, image 1 of 1
      • Lift the LCD screen ZIF connector tab and remove the ribbon cable.
      • Detach the no-fuss connector.
      • Lift the screen from its holder.
      Ask FixBot
    1. Canon PowerShot SX600 HS Flash Assembly Replacement, Flash Assembly: step 14, image 1 of 1
      • Unplug the assembly from the main no-fuss connector.
      Ask FixBot
    2. Canon PowerShot SX600 HS Flash Assembly Replacement: step 15, image 1 of 1
      • Unplug the assembly from its flat-top connection.
      Ask FixBot
    3. Canon PowerShot SX600 HS Flash Assembly Replacement: step 16, image 1 of 1
      • Use a #000 Phillips screwdriver to remove the three 4mm screws that hold the assembly to the frame.
      Ask FixBot
    4. Canon PowerShot SX600 HS Flash Assembly Replacement: step 17, image 1 of 1
      • Gently lift the assembly out of its place.
      Ask FixBot
Fix your Canon's flash in order to take bright, vibrant photographs.
2 other people completed this guide.
Scott Childress
770 Reputation
3 Guides authored
USF Tampa, Team S6-G4, Lacy Spring 2017 Member of USF Tampa, Team S6-G4, Lacy Spring 2017
USFT-LACY-S17S6G4
3 Members
72 Guides authored
1 Guide Comment
my SX610 HS flash didn't work. im trying to just troubleshoot it to see if it might came loose or anything. do i still need to do all steps?
Nurul Huda Mohd Asri - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 44
All Time: 1,529
