Canon PowerShot S50 won't turn on
No matter what you do, you can't get your Canon PowerShot S50 camera to turn on.
Hold switch on
Before getting into the guts of your Canon PowerShot S50, pressing the on/off switch. If the camera does not turn, read on.
Drained/bad battery
If your camera will not turn on, it is possible the battery is drained and needed to be replaced. First try to charge your battery in its accompanying charger that came with the camera. If the camera does not turn on with the newly charged battery in place, you may need a new battery. This guide will help you replace the Battery.
Bad display
It is possible that it appears nothing is happening because the display is bad. If you feel as though you need to replace, follow the installing and LCD Screen.
Bad Motherboard
If the camera will not function, there may be a problem with the motherboard. It could have short circuited or something could have gone wrong inside but the camera will no longer work. There are individual guides for both the Right Motherboard and Left Motherboard.
Battery Won't Charge
If the battery won't charge, it is possible you need a new battery. Follow the installing a new Battery guide to replace.
Bad Battery
To check if you have a bad battery, try charging it back in the charger. If it will not hold a charge, when you replace it back into the camera, the battery is most likely broken. If you have a bad battery, you can purchase a new one for this camera. This guide will help you replace the Battery.
Bad Charger
If a new battery can not hold a charge, there may be a problem with your charger. In order to fix this, you can buy a new charger for this device here.
Camera Lens Gets Stuck
Camera Won't Turn on
If you slide the lens cover open, and the lens doesn't extend outwards, it may be broken.
Flash Won't Work
"Your camera won't take a photo with a flash!"
Broken Flash Unit
If your flash won't work, it is possible the flash unit is broken. If this is the case, it may need to be replaced. A replacement can be purchased here.
Author
with
Karim
45 Reputation
3 Guides authored
Cal Poly, Team 7-34, Maness Spring 2012 Member of Cal Poly, Team 7-34, Maness Spring 2012
CPSU-MANESS-S12S7G34
5 Members
72 Guides authored
2 Comments
purchased camera at dick smith store in maitland last yearused 3 timescamera keeps telling me to charge batteryhad battery replacestill the same,maitland battery tell me battery ok,still no luckpush down on the off on buttoncamera tell me to charge battery,,leans opens and then closes,
Anthony Cagney - Reply Share
The lens of myCanon Powershot S50 would not retract far enough to use lens cover. I went to fixit on Safari, desperate for advise.
After gently passing, tapping, prying, hitting harder for 3 days, off and on, this morning I whacked it and the lens fully retracted.
It took persistence and fixit to get my dear, old Canon to operate.
Thank you.
martinsklar - Reply Share
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 40
All Time: 6,165
