Canon PowerShot S50 Left Motherboard Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
47
All Time:
1,783
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to remove and/or replace the motherboard on the left side of the camera.
Tools
    1. Canon PowerShot S50 Left Motherboard Replacement, Battery: step 1, image 1 of 2 Canon PowerShot S50 Left Motherboard Replacement, Battery: step 1, image 2 of 2
      • Place camera LCD side up and press up on the battery door.
      • Let it swing open until you can see the battery inside.
      Ask FixBot
    2. Canon PowerShot S50 Left Motherboard Replacement: step 2, image 1 of 1
      • Press down on the orange plastic.
      • This will gently eject the battery from its compartment.
      Ask FixBot
    3. Canon PowerShot S50 Left Motherboard Replacement: step 3, image 1 of 2 Canon PowerShot S50 Left Motherboard Replacement: step 3, image 2 of 2
      • Holding the edges, slide out the battery.
      Ask FixBot
    1. Canon PowerShot S50 Left Motherboard Replacement, Front Panel/Battery Door: step 4, image 1 of 1
      • Look at the camera from the side with the lanyard and 4 screws.
      • Remove the two 3.4 mm screws on the metallic colored part.
      Ask FixBot
    2. Canon PowerShot S50 Left Motherboard Replacement: step 5, image 1 of 1
      • Remove the 3mm screw on the top left.
      • NOTE: When reassembling, it is helpful to put the top screw back in before placing the front cover back on the camera.
      • Now remove the 5.3mm screw on the bottom.
      Ask FixBot
    3. Canon PowerShot S50 Left Motherboard Replacement: step 6, image 1 of 1
      • Place the camera LCD side down.
      • Remove the two 5.3mm screws by the battery door.
      Ask FixBot
    4. Canon PowerShot S50 Left Motherboard Replacement: step 7, image 1 of 1
      • Remove the four 3.4mm screws on the bottom of the camera around the tripod mount.
      • Make sure to keep these screws separate from the previous 5.3 mm screws.
      Ask FixBot
    5. Canon PowerShot S50 Left Motherboard Replacement: step 8, image 1 of 1
      • Stand the camera back up.
      • Remove the two 3.6mm screws on the side with the A/V Out port.
      Ask FixBot
    6. Canon PowerShot S50 Left Motherboard Replacement: step 9, image 1 of 1
      • Lift open the rubber flap covering the A/V Out port.
      • Remove the 3.4mm screw in the center.
      • During reassembly, put the A/V out rubber door on before replacing the front panel of the camera
      Ask FixBot
    7. Canon PowerShot S50 Left Motherboard Replacement: step 10, image 1 of 1
      • Use a spudger and gently open up the front panel of the camera.
      • A thin plastic ribbon will stay connected by a brown piece to front panel of the camera.
      Ask FixBot
    8. Canon PowerShot S50 Left Motherboard Replacement: step 11, image 1 of 1
      • There will be a brown plastic piece keeping the thin plastic ribbon in place.
      • Use the spudger to pull out the brown plastic piece attached to the orange plastic.
      Ask FixBot
    9. Canon PowerShot S50 Left Motherboard Replacement: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers and remove the metal piece inside the camera.
      Ask FixBot
    10. Canon PowerShot S50 Left Motherboard Replacement: step 13, image 1 of 1
      • Remove the battery door
      • NOTE: Putting this back on requires aligning the spring on the back of the door with the hole on the camera
      Ask FixBot
    1. Canon PowerShot S50 Left Motherboard Replacement, Left Motherboard: step 14, image 1 of 1
      • Disconnect the black and red cable on the left side of the lens.
      Ask FixBot
    2. Canon PowerShot S50 Left Motherboard Replacement: step 15, image 1 of 1
      • Disconnect the two orange ribbons on the front of the mother board.
      Ask FixBot
    3. Canon PowerShot S50 Left Motherboard Replacement: step 16, image 1 of 1
      • Pull off the orange ribbon on the upper left of the motherboard.
      • This will become available only after removing the ribbon on top.
      • Remove the other two orange ribbons on the middle of the left motherboard.
      Ask FixBot
    4. Canon PowerShot S50 Left Motherboard Replacement: step 17, image 1 of 1
      • Remove the 3.3mm screw halfway up the left side of the motherboard just to the left of the lens.
      • Go under the piece of plastic and remove the 2.6mm screw.
      Ask FixBot
    5. Canon PowerShot S50 Left Motherboard Replacement: step 18, image 1 of 2 Canon PowerShot S50 Left Motherboard Replacement: step 18, image 2 of 2
      • Unplug the top part of the left motherboard.
      • Gently lift the left motherboard up to remove
      Ask FixBot
Jacob
16 Reputation
3 Guides authored
Cal Poly, Team 7-34, Maness Spring 2012 Member of Cal Poly, Team 7-34, Maness Spring 2012
CPSU-MANESS-S12S7G34
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 47
All Time: 1,783
