Camera won't turn on
The camera won't turn on! When you press the power button, nothing happens whatsoever.
Check power button
Make sure the button presses down all the way. Hold the button for 5 seconds. If the power still does not turn on, try the next step.
Drained/bad battery
Make sure you charge your battery by plugging it in to a power source. Try turning it on again, and if it still does not work, something is probably wrong with one of the components. Replace the batteries first. Check the batteries and the battery chamber for dirt as well. Clean off any dirt with cotton dipped in isopropyl alcohol (rubbing alcohol).
Bad logic board
If the camera is charged and still does not turn on, the electrical components inside of the camera need to be replaced.
Doesn't take pictures or videos
The camera turns on and the screen works, but it won't take any pictures or video.
Check memory
It may be that your camera has no room for more photos or videos. Navigate to playback mode, and if images or videos appear you can delete them to free up storage space.
Memory card does not work/have space
The camera does not register your memory card, or won't save pictures to it.
Identify SD card on camera
Check the SD card slot for an SD card. If the SD card is inserted and you cannot access it on the camera, turn the camera off and on.
Faulty SD card
If the SD card still does not work, it may be faulty. Try testing it with another working device, or trying a known working SD card in the camera.
Faulty SD card reader
If the camera still doesn't detect your SD card, it might have a broken card reader. You will need to replace it.
Function buttons don't work
The screen is working, but the buttons next to it don't respond.
Faulty buttons
If the buttons are stuck and won't budge, try to shift them until they do. Otherwise, the buttons probably need to be replaced.
The LCD stays dark when the camera is on
The screen does not work, but the rest of the camera seemingly does.
One or two colored dots
If you occasionally see only one or two red dots, then they will pass. This is normal and does not require any repair.
Replace screen
You probably have to replace the screen if it's the only thing not working.
Flash doesn't go off
The camera does not flash when you take a picture.
Correct Modes
Make sure the camera is set to "Camera mode". The camera will not take a picture unless the flash is charged, which will be indicated by an orange indicator above the playback screen. The flash setting also has to be on; it is often defaulted to "automatic," which would have to be changed if you want it to always flash.
Burnt out flash
The flash may be burnt out, in which case it should be replaced. Use the Flash unit repair guide to remove the faulty part.
Zoom doesn't work
The camera does not allow you to zoom in or out when taking a picture or video.
Broken switch
If the switch for the zoom feels loose, you may have to replace it.
Broken zoom lens
If the switch feels functional, the other possibility is that the zooming part of the camera is broken. This will have to be repaired/replaced.
AutoFocus light on camera keeps blinking
Orange light on the camera is continuously blinking.
Auto-Focus function
If an orange light is blinking while taking a picture, this is the auto-focus function that helps the camera focus in low lighting. To deactivate the auto-focus, enter the function menu, find the AF function and set it to "off".
Loose internal ribbon cable
If this happens abnormally, it is possible that a ribbon cable inside the camera may have come loose. Follow the Motherboard/Capacitor repair guide to locate and fixate any ribbon cables.
Andrew Elliott
13 Reputation
1 Guide authored
Cal Poly, Team 17-30, Amido Spring 2012 Member of Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Members
72 Guides authored
3 Comments
Everything works except I can't see anything in the display to take a image after pressing the DISP. button
BK Morrow - Reply Share
Here are couple things to try to see which part isn't working. 1)press the menu button on the back, if the menu does show up and you can change selections using the wheel to the right then the display is ok.
2) and this is the most common, the picture CCD image sensor is bad. Make sure you have a memory card in and good batteries. Try taking a picture using the optical viewfinder. Use the slide switch to change to picture playback. If a picture shows up it may still be a bad display. Mine works fine for a while then goes black. If there is no picture or it's a purple smear then the CCD image sensor is bad. You can also try connecting it to your computer to see if there's a valid picture. Canon was replacing the CCD free of charge even after warranty ( they had gotten bad sensors from a supplier) but they may have stopped that. Send them an email from their website. They replaced the sensor on mine 5yrs after in was out of warranty.
Don Minish - Reply Share
The camera works fine until you try to take a photo or video, where the screen goes black, and any photos or videos you take are black, everything else works fine, and I can see pictures that were previously taken on the camera. Any help?
Fizzfozz - Reply Share
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 49
All Time: 5,563
