Canon PowerShot A75 Batteries Replacement
  1. Canon PowerShot A75 Batteries Replacement, Batteries: step 1, image 1 of 1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
    Ask FixBot
  2. Canon PowerShot A75 Batteries Replacement: step 2, image 1 of 3 Canon PowerShot A75 Batteries Replacement: step 2, image 2 of 3 Canon PowerShot A75 Batteries Replacement: step 2, image 3 of 3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
    Ask FixBot
  3. Canon PowerShot A75 Batteries Replacement: step 3, image 1 of 3 Canon PowerShot A75 Batteries Replacement: step 3, image 2 of 3 Canon PowerShot A75 Batteries Replacement: step 3, image 3 of 3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
    Ask FixBot
Put in fresh batteries. Gently shut the flap and slide it forward until you hear a click.
Henry Braden Fisk
63 Reputation
1 Guide authored
Cal Poly, Team 17-30, Amido Spring 2012 Member of Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Members
12 Guides authored
4 Guide Comments
Hi, there is a problem with my Powershot a75. Whenever I switch it on, it just says change the batteries even though they are either new, or fully charged. Thanks
Harry collier - Reply Share
had same trouble i fix it buy pressing the print button on back next to the disp button it should work then
hot5 - Reply Share
Probably you have change backup battery which is rechargeable and not easy to change. It is close to chargeable outlet.
Maganbhai Patel - Reply Share
Bonjour j'ai un petit problème avec mon appareil photo. J'essaye de l'ouvrir avec le bouton mais elle ne s'allume pas et les supports de piles ont rouillé et la carte orange à été un peu touché par la rouillé aussi. Comment pourrais-je le faire fonctionner?
Leyla minal - Reply Share
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 57
All Time: 2,949
