OontZ Angle Plus Does Not Turn On
OontZ Angle Plus does not show any signs of powering on.
Battery is Out Of Charge
The problem could be that the battery does not have enough power for OontZ Angle Plus to turn on. Before disassembling your Oontz Angle Plus try to charge it and see if it turns on.
Disconnected Wires
It is possible for one or more wires to get disconnected from the battery. If that is the case disassemble your device and reattach them using this guide.
Faulty Battery
It is possible for the battery to break after prolonged use. If that is the case disassemble your device and check for other problems before replacing the battery. If there are no other problems replace the battery using this guide.
One Speaker Does Not Work
One or more speakers does not make any sound.
AUX Cable Is Not Plugged in All The Way
Sound issues can occur if cables are not plugged in all the way. Check if the AUX cable is plugged in all the way. If not try to plug it in all the way.
No Power Coming to The Speaker
Sometimes wires can get disconnected from speakers. Check if there is power coming to the speaker by disassembling the speaker and checking the wire connections. If not use this guide to connect it.
No Audio Coming from The Computer
There is no audio coming from the computer.
Check if The Speaker is Turned On
Check if the speaker is turned on, if it is off and you cannot turn it on refer to this section.
Check The Audio Cable And Settings
It is possible for audio cable to be broken or for the volume to be turned down to zero. Make sure that the audio cable is completely inserted and try to increase the sound level. Also try to check if the cable is not working by using a different one. If the cable is working and the speaker is on check if the AUX port is not working. If that is the case refer to this guide to replace or reconnect the motherboard.
No Audio Coming from The Bluetooth Device
There is no audio coming from the Bluetooth device.
Check if The Device Is Paired To The Speaker
It is possible to the speaker is not connected to the Bluetooth Device. Check to see if the Bluetooth device is paired to the speaker and make sure that the volume is turned up. Try restarting the Bluetooth device and the speaker. If that does not resolve the issue check wiring to the speakers and battery using this guide.
USB and AUX Ports Are Not Working
AUX or USB port is not working.
Cable Is Not Working
It is possible that the cable is broken. Check if the cable you used is faulty by using a different USB/AUX cable. If that is the case replace or repair the faulty cable.
Ports Are Not Attached to The Motherboard
If USB or AUX port is not attached to the motherboard then you will be unable to use it. Check if that is the case by disassembling your speaker and looking at the points where the ports should be attached. You can locate them or replace the motherboard using this guide.
Crackling Sounds Coming From Speaker
Crackling sounds coming from the speaker
Faulty AUX connection
It is possible that the cable is not plugged in properly or that the speakers are not connected properly. Check if the AUX cable is plugged in all the way and that all cables inside of the speaker are properly connected. If not use this guide to connect them.
Popping Sounds Coming From The Speaker
Popping sounds coming from the speaker
Too Close To Other Speakers
It is possible for other speakers to cause interference with the connection. Try to use a different cable or move the speaker away from other speakers and cables.
It is possible for AUX port to be disconnected or for the cable to not be connected properly. Check if the AUX cable or the AUX port is properly connected and if speakers are properly connected. If not use this guide to locate the AUX port.
Author
with
Artem Nykolenko
203 Reputation
1 Guide authored
USF Tampa, Team 1-1, Nance Spring 2016 Member of USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 9,255
