Cambridge SoundWorks OontZ Angle Plus Motherboard Replacement
    1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: step 1, image 1 of 2 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Lower Casing: step 1, image 2 of 2
      • Pull back the six screw covers on the bottom of the device.
      • Starting from the screw covers, peel the casing away from the bottom plate.
      Ask FixBot
    1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Battery: step 2, image 1 of 1
      • Unscrew the five 11.5mm Phillips screws on the bottom plate.
      Ask FixBot
    2. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: step 3, image 1 of 1
      • Carefully pull apart the bottom plate and the top plate, using the blue plastic opening tool.
      Ask FixBot
    3. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: step 4, image 1 of 1
      • Once the bottom plate and the top plate are separated, slowly pull the back plate away from the top plate.
      • There are wires connected to both plates so do this step with care.
      Ask FixBot
    4. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: step 5, image 1 of 1
      • Unscrew the two 10 mm Phillips screws on the brace holding down the battery.
      • Remove the brace that holds the battery in place.
      Ask FixBot
    5. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: step 6, image 1 of 1
      • Separate the battery from the bottom plate and set the bottom plate aside.
      Ask FixBot
    6. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: step 7, image 1 of 1
      • With some force, push the motherboard straight in toward the center of the device.
      Ask FixBot
    7. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: step 8, image 1 of 1
      • Pull the motherboard straight out of the device.
      • There is some adhesive on the motherboard that holds it in place. This make the motherboard fit in the groove rather tight.
      Ask FixBot
    8. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: step 9, image 1 of 1
      • Desolder the wires that connect the battery to the motherboard, negative (black wire) and positive (red wire).
      Ask FixBot
    1. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement, Motherboard: step 10, image 1 of 1
      • Unplug the wires that connect the speakers to the motherboard.
      Ask FixBot
    2. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: step 11, image 1 of 1
      • Unplug the thin white cable connected to the buttons.
      Ask FixBot
    3. Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: step 12, image 1 of 2 Cambridge SoundWorks OontZ Angle Plus Motherboard  Replacement: step 12, image 2 of 2
      • Desolder the wires that connect the LED to the motherboard.
      Ask FixBot
Farshad Mohebban
524 Reputation
4 Guides authored
USF Tampa, Team 1-1, Nance Spring 2016 Member of USF Tampa, Team 1-1, Nance Spring 2016
USFT-NANCE-S16S1G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 2,127
