Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Label Maker Not Printing
The print paper is not coming out of the back of the device.
Empty Tape Cassette
If you notice no paper coming out, the cartridge/cassette might be out of paper or damaged. If so, you can look at either the product manual or our guide to replace it.
Plastic Print Roller Lever Piece Broken
Turn your device around, and open the tape cover. Next, push down on the plastic lever directly below the tape cartridge. If the black cylindrical piece on the right does not move, then the connection between the lever and the roller might be disconnected.
Refer to this guide to retrieve and replace the piece.
Unresponsive Motor
If checking and replacing the cartridge and/or the print roller did not fix your problem, it may be a faulty motor. Listen carefully after pressing the print button, if you hear nothing, the problem is most likely with the motor. Refer to this guide to replace it.
Paper Not Being Cut
The cutter is not cutting the paper.
Dull/Missing Cutter
If the scissors are not cutting the paper, go to the product manual or refer to our guide to replace them.
Keyboard Not Working
Nothing happens when the keys are pressed.
Missing Keypad Contacts
When some/all buttons on the keypad don't respond or require too much force, you should replace the keypad. Refer to this guide on how to do so.
Label Maker Will Not Turn On
The display does not work and there is no response when pressing the keys.
Drained Batteries
You will need to replace the batteries when your device does not turn on. Either look at the product manual or check out our guide.
Author
with
Kimberly Larsen
291 Reputation
5 Guides authored
IUPUI, Team 1-1, Harley Fall 2016 Member of IUPUI, Team 1-1, Harley Fall 2016
IUPUI-HARLEY-F16S1G1
3 Members
84 Guides authored
1 Comment
Won’t turn on - also might be the internal cable to the display has become disconnected.
To fix this, remove the back cover, cassette and batteries. Next remove 6 screws and open the case carefully. Check the ribbon cable from the back of the display is securely connected to the the socket on the circuit board. If not, reinsert it and press the retaining clips carefully into place to secure the ribbon cable. Reassemble, reinsert batteries and cassette and try the power switch.
Matt - Reply Share
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 42
All Time: 4,813
