Brother PT-110 Print Roller Lever Replacement
  1. Brother PT-110 Print Roller Lever Replacement, Batteries: step 1, image 1 of 2 Brother PT-110 Print Roller Lever Replacement, Batteries: step 1, image 2 of 2
    • Push on the side of the cover, and remove it.
  2. Brother PT-110 Print Roller Lever Replacement: step 2, image 1 of 1
    • Remove the batteries.
  3. Brother PT-110 Print Roller Lever Replacement, Back Plate: step 3, image 1 of 2 Brother PT-110 Print Roller Lever Replacement, Back Plate: step 3, image 2 of 2
    • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
    • Total: 2 x Screws
  4. Brother PT-110 Print Roller Lever Replacement: step 4, image 1 of 1
    • First: To separate the top cover from the body, insert a spudger between the two halves.
    • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
    • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
  5. Brother PT-110 Print Roller Lever Replacement: step 5, image 1 of 1
    • Gently separate the two covers, ensuring wires are not taut.
  6. Brother PT-110 Print Roller Lever Replacement: step 6, image 1 of 1
    • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
  7. Brother PT-110 Print Roller Lever Replacement: step 7, image 1 of 2 Brother PT-110 Print Roller Lever Replacement: step 7, image 2 of 2
    • Carefully pinch the top of the connector.
    • Pull perpendicular to the device until the wire is disconnected.
    • It may require more force than expected to disconnect the wires.
  8. Brother PT-110 Print Roller Lever Replacement: step 8, image 1 of 3 Brother PT-110 Print Roller Lever Replacement: step 8, image 2 of 3 Brother PT-110 Print Roller Lever Replacement: step 8, image 3 of 3
    • Unscrew the three 9 mm Phillips #1 screws shown.
    • Total: 3 x Screws
  9. Brother PT-110 Print Roller Lever Replacement, Print Roller Lever: step 9, image 1 of 1
    • Using the metal spudger, swivel the pin so that the print roller lever loosens.
  10. Brother PT-110 Print Roller Lever Replacement: step 10, image 1 of 1
    • Gently pull the print roller lever out.
4 other people completed this guide.
Kimberly Larsen
279 Reputation
5 Guides authored
IUPUI, Team 1-1, Harley Fall 2016 Member of IUPUI, Team 1-1, Harley Fall 2016
IUPUI-HARLEY-F16S1G1
3 Members
7 Guides authored
6 Guide Comments
Hi everybody ,does anyone knows were I can by such a lever ?
TBH
Daniel Verkest - Reply Share
BONJOUR, (I’m French)
Same question: does anyone knows were I can by such a lever ?
Pegase M - Reply Share
Did anyone find a source for this part?
Erik Carlson - Reply Share
Unfortunately very discontinued. Until someone adds it to thingverse there's not much that can be done.
UN8026001 ROLLER HOLDER ASSY PT100/110
UN8031001 ROLLER HOLDER SPRING PT100
UN8032000 ROLLER RELEASE LEVER PT100/110
Michael Krieger - Reply Share
I can fix these by using plastic weld to rebuild the edging. I was totally successful.
George Pede - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 52
All Time: 2,256
