Up to 20% off select tools
Brother PT-110 Keypad Contacts Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
88
All Time:
843
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to take apart the back panel to replace the keypad contacts.
    1. Brother PT-110 Keypad Contacts Replacement, Batteries: step 1, image 1 of 2 Brother PT-110 Keypad Contacts Replacement, Batteries: step 1, image 2 of 2
      • Push on the side of the cover, and remove it.
      Ask FixBot
    2. Brother PT-110 Keypad Contacts Replacement: step 2, image 1 of 1
      • Remove the batteries.
      Ask FixBot
    1. Brother PT-110 Keypad Contacts Replacement, Back Plate: step 3, image 1 of 2 Brother PT-110 Keypad Contacts Replacement, Back Plate: step 3, image 2 of 2
      • Remove the cartridge and the yellow tape cutter.
      • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
      • Total: 2 x Screws
      Ask FixBot
    2. Brother PT-110 Keypad Contacts Replacement: step 4, image 1 of 1
      • First: To separate the top cover from the body, insert a spudger between the two halves.
      • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
      • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
      • A small flat screwdriver works for this step. Use on the left and right sides.
      Ask FixBot
    3. Brother PT-110 Keypad Contacts Replacement: step 5, image 1 of 1
      • Gently separate the two covers, ensuring wires are not taut.
      Ask FixBot
    4. Brother PT-110 Keypad Contacts Replacement: step 6, image 1 of 1
      • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
      Ask FixBot
    5. Brother PT-110 Keypad Contacts Replacement: step 7, image 1 of 2 Brother PT-110 Keypad Contacts Replacement: step 7, image 2 of 2
      • Carefully pinch the top of the connector.
      • Pull perpendicular to the device until the wire is disconnected. Remove the other connector by pulling it parallel to the circuit board.
      • It may require more force than expected to disconnect the wires.
      Ask FixBot
    6. Brother PT-110 Keypad Contacts Replacement: step 8, image 1 of 3 Brother PT-110 Keypad Contacts Replacement: step 8, image 2 of 3 Brother PT-110 Keypad Contacts Replacement: step 8, image 3 of 3
      • Unscrew the three 9 mm Phillips #1 screws shown.
      • Total: 3 x Screws
      • Lift the metal plate upwards, don't unscrew the motor, this will remain attached to the plate. If you didn't remove the yellow tape cutter then it will simply fall out.
      Ask FixBot
    1. Brother PT-110 Keypad Contacts Replacement, Keypad Contacts: step 9, image 1 of 2 Brother PT-110 Keypad Contacts Replacement, Keypad Contacts: step 9, image 2 of 2
      • Unscrew both 6 mm Phillips #1 screws from the circuit board.
      • Total screws: 2
      Ask FixBot
    2. Brother PT-110 Keypad Contacts Replacement: step 10, image 1 of 1
      • Gently lift the circuit board out.
      Ask FixBot
    3. Brother PT-110 Keypad Contacts Replacement: step 11, image 1 of 1
      • Peel the keypad contacts up from the plastic casing.
      Ask FixBot
Author
with
Kimberly Larsen
291 Reputation
5 Guides authored
IUPUI, Team 1-1, Harley Fall 2016 Member of IUPUI, Team 1-1, Harley Fall 2016
IUPUI-HARLEY-F16S1G1
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 88
All Time: 843
