Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
BLU Dash D140 SD card not primary storage
Nothing is saved to the SD card.
BLU Dash D140 has an unrecognizable SD card
****Make sure the SD card is pushed into the slot all the way.***
Pull out the SD card and blow on it, sometimes dust particles can keep your SD card from being read.
BLU Dash D140 primary storage not set
Follow these directions:
  1. Start in settings
  2. Go to applications
  3. Then go to preferred install location
  4. Select internal storage
BLU Dash D140 has broken SD card slot
Very rare, but sometimes the SD card slot on your phone could be malfunctioning. If you have a functioning SD card you can do this by putting in the SD card in another phone to see if the phone reads it. If the phone reads it, then try it in the BLU Dash JR D140. If it is not read try blowing on the SD card and slot and trying again. It's recommended you get hold of BLU customer service if the slot is broken. If you're under warranty BLU will cover it!
BLU Dash JR D140 opens apps slowly
Opening apps has been taking forever.
BLU Dash D140 has a virus or is bogging out
Usually a full reset with these types of phones recovers stock speeds because the phone has more space to work with and cleans any bugs in the phones!
  1. Hold down the home button, volume-up button, and power button simultaneously for 15 seconds until you see the Blu logo screen pop up and then you release all the buttons.
  2. Once the Blu logo screed fades and the broken Android logo shows up, push the power button to open the recovery options.
  3. Use the volume-down button to navigate.
  4. Go down until you hit "wipe data/factory reset" and then press the volume up button to select it.
  5. Then select "yes."
  6. Once the process is done, it will boot up and will be ready for use.
BLU Dash D140 is not fully charged
If the device is working slow, it is common for this to happen at low percentage battery life. Fully charge the phone and see if the speeds increase.
BLU Dash D140 lacks space
The biggest SD card available for this device is 32gb. SD cards are like hard drives for phones. Installing many apps can slow down the phone, adding a bigger storage creates more space to work with.
BLU Dash D140 battery won't charge
The battery won't charge, gets really hot, or loses charge right away when you unplug it.
BLU Dash D140 loses charge quickly
If your battery can't hold its charge anymore and drains extremely fast, you might be able to save it by doing a full recharge. You'll need to completely drain the battery for this to work, so once it reaches zero percent, keep turning it back on until it doesn't even have enough power to boot. Now, plug in the power cord (to a power outlet) and let the battery charge for at least 48 hours.
BLU Dash D140 faulty battery
Replace battery, but prior to purchase make sure that the battery prong connectors are on the same side as on your current battery. Follow this guide to replace the battery.
BLU Dash D140 microphone isn't picking up anything
The microphone doesn't pick up communication.
BLU Dash D140 has broken microphone
If the microphone isn't picking up anything it might need to be replaced. There is a replacement guide here. If you're still under warranty BLU will replace it.
BLU Dash D140 has dirty microphone
Follow our microphone replacement guide, but instead of replacing the microphone, clean it and put the phone back together. Sometimes debris can alter the communication.
BLU Dash D140 can't see what's on screen
Phone shows distortion.
BLU Dash D140 has cracked screen cover
Follow this replacement guide to replace the screen cover.
BLU Dash D140 has broken LCD
If the phone is still under warranty it will be covered, but, if not, use the screen replacement guide to access the LCD screen and replace it. Notice that to replace the LCD you have to take the phone apart fully. So be comfortable with the situation and make sure you have time because depending on experience it could be a while.
BLU Dash D140 has dirty screen
Use the replacement guide to get under the screen and clean it with a damp wet cloth (with water). Sometimes just a little screen cleaner from any phone store will work as well. Smudges and dirt particles can be a nuisance and should be cleaned!
Jocelyn Patterson
43 Reputation
0 Guides authored
UW Tacoma, Team 1-4, Liner SU 2015 Member of UW Tacoma, Team 1-4, Liner SU 2015
UWT-LINER-SU15S1G4
4 Members
24 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 2,425
