BLU Dash JR D140 Microphone Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
89
All Time:
909
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will take a bit of time so make sure your schedule is free before you attack this guide! If you have no soldering experience I suggest looking at Ifixits guide on soldering here.
Tools
    1. BLU Dash JR D140 Microphone Replacement, Battery: step 1, image 1 of 1
      • Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
      • Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
      Ask FixBot
    2. BLU Dash JR D140 Microphone Replacement: step 2, image 1 of 1
      • Using a plastic opening tool or finger, pull out the battery.
      Ask FixBot
    1. BLU Dash JR D140 Microphone Replacement, Microphone: step 3, image 1 of 1
      • Remove the four 4.0mm Phillips #1 screws.
      Ask FixBot
    2. BLU Dash JR D140 Microphone Replacement: step 4, image 1 of 2 BLU Dash JR D140 Microphone Replacement: step 4, image 2 of 2
      • Starting from a corner, separate the panel from the frame using the plastic opening tool.
      • The volume button will pop out.
      Ask FixBot
    3. BLU Dash JR D140 Microphone Replacement: step 5, image 1 of 1
      • Unscrew the 3.6mm Phillips #0 screw from the motherboard.
      Ask FixBot
    4. BLU Dash JR D140 Microphone Replacement: step 6, image 1 of 1
      • Using a spudger, lift the black ZIF connector at the top left corner of the phone.
      Ask FixBot
    5. BLU Dash JR D140 Microphone Replacement: step 7, image 1 of 1
      • Pull the ribbon cable out of the ZIF connector.
      Ask FixBot
    6. BLU Dash JR D140 Microphone Replacement: step 8, image 1 of 1
      • When the ribbon cable is removed from the ZIF connector, peel off the power sticky button using a plastic opening tool.
      Ask FixBot
    7. BLU Dash JR D140 Microphone Replacement: step 9, image 1 of 1
      • Peel off the volume sticky button.
      Ask FixBot
    8. BLU Dash JR D140 Microphone Replacement: step 10, image 1 of 1
      • Separate the screen cover from the motherboard using the plastic opening tool.
      • Make sure that the LCD screen stays attached to the motherboard while doing this.
      Ask FixBot
    9. BLU Dash JR D140 Microphone Replacement: step 11, image 1 of 3 BLU Dash JR D140 Microphone Replacement: step 11, image 2 of 3 BLU Dash JR D140 Microphone Replacement: step 11, image 3 of 3
      • The microphone is at the bottom left corner of the phone.
      • Lift the microphone very carefully. Unsolder the two lower wires (one red wire and one black wire).
      • If you don't feel comfortable with this step I recommend looking at Ifixit's solder guide here.
      • Solder the new microphone in the same spot. The black wire will go in the left spot and the red wire in the right spot.
      Ask FixBot
2 other people completed this guide.
Saravpreet singh
179 Reputation
1 Guide authored
UW Tacoma, Team 1-4, Liner SU 2015 Member of UW Tacoma, Team 1-4, Liner SU 2015
UWT-LINER-SU15S1G4
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 89
All Time: 909
