Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
This page will help you troubleshoot issues for the August Smart Lock.
There is no light on the front of the lock
The device has light on the front of the lock the flashes when being activated. The LED is not working even though the lock has power.
Faulty LED
You may have to replace the LED light that is located within the device. The LED is an indicator of connection as well as power.
Speaker is not making noise
The device has power but is not making any noise when unlocking or locking. This is indicated by the LED working demonstrating that the lock still has power.
Speaker is broken
There is a possibility that the speaker located within the device is busted. Follow the replacement guide here for help with that issue.
Motherboard has faulty component
If replacing the speaker does not work, you may have to go in and replace the motherboard. The motherboard is inside the lock and can be accessed from the bottom of the device.
Device shows no response
The device is not powering on and there is no flashing light on the front. The device will not connect to any smartphone either.
Batteries are dead
If the device is not powering on, the first thing to try and do is replace the batteries. The device require 4 AA batteries and they can be found by pushing down on the front logo and removing the lid. After removing the lid, you will find the batteries. To get to the ones beneath the visible ones, pull the red flap.
Device not connecting to the phone
The device manually locks but does not lock with while using the application. The device has power but the app is unable to connect to the lock.
August Connect
To connect to your device from far away, the August Connect will need to be purchased. More information can be found on the August website.
Bluetooth Settings
If you cannot connect to your device, there is a chance that you need to make sure that the smartphone that you are using is connecting to the device via bluetooth. Go to the settings in your phone and make sure that bluetooth is on and that it is connected to the device.
Faulty motherboard
If the above does not fix the issue, there may be an issue with the motherboard. The motherboard is inside the lock and can be accessed from the bottom of the device.
Device is not unlocking or locking the door
The device has power but is not unlocking or locking the door. There is no motion within the lock itself except when using manually.
Batteries are dead
There is a possibility if the device is not working properly that the batteries are dead. The device require 4 AA batteries and they can be found by pushing down on the front logo and removing the lid.
WIFI Settings
If you are located far from your device and not connected to it via bluetooth, the device can still function using WIFI. Check your WIFI setting and make sure you are connected via WIFI. Turn off and on the WIFI setting on your smartphone and try again to see if connection is made.
Bluetooth Connectivity
Make sure that you are connected to your device via Bluetooth. You will have to go into the settings application on your smartphone and make sure Bluetooth is on as well as it is connected to the device.
The Gears Are Not Functioning
There is a possibility one of the gears inside the lock broke. The gears are located within the lock and accessed through the bottom of the device. In order to replace it, follow the guide here.
The accelerometer needs replacing
The accelerometer is one of the key components to making the device turn. Along with the motor and the gears, it is helps control the turning and the speed at which the device turns. To replace the accelerometer, follow the guide here.
Faulty motherboard
If the above does not solve the issue, there is a possibility that you may have to replace the motherboard. The motherboard is located within the device and needs to be accessed in the bottom part of the device.
Author
with
Zac Carpenter
58 Reputation
0 Guides authored
USF Tampa, Team S11-G6, Passmore Fall 2017 Member of USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Members
36 Guides authored
9 Comments
where can is but the accelerometer?
mm mm - Reply Share
where can i get the faulty led?
alci Frerdewich - Reply Share
My app keeps asking for me to authenticate. When I use the password that I have always used it says, “retry”. So, I changed my password and when i tried the new password is continues to say retry. How can I correct this problem. August can’t seem to know how.
Charles Cohlmia - Reply Share
My batteries are dying very fast, lock lines up properly, happened after I moved and moved back. Batteries dead within a week. Any suggestions?
Dustin Jones - Reply Share
My batteries died within 2 months then they have to be changed as well as no guests can get into the unit I have to make everybody A owner which is faulty tried having it fixed with August on several occasions finally got to the point where I wanted to return it they're telling me they're not going to exchange it the store I bought it at only gives you 30 days the problems started right from day one when we try to install it I spent the seven days on the phone trying to get the lock to work properly and this is how they treat me
allan rookes - Reply Share
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 63
All Time: 45,440
