Up to 20% off select tools
August Smart Lock Gear Replacement
Views: 15K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
149
All Time:
14,605
Comments: 12
3 comments on steps, 9 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to replace the gears that are located within the device. The gears can malfunction causing issues with the rotating of the lock.
    1. August Smart Lock Gear Replacement, Gear: step 1, image 1 of 3 August Smart Lock Gear Replacement, Gear: step 1, image 2 of 3 August Smart Lock Gear Replacement, Gear: step 1, image 3 of 3
      • Flip the device over so the metal plate is facing you.
      • Undo the latches on the side to remove the metal plate.
      • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
      • To unscrew all of the screws, you will need to close the latches again.
      • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
      Ask FixBot
    2. August Smart Lock Gear Replacement: step 2, image 1 of 3 August Smart Lock Gear Replacement: step 2, image 2 of 3 August Smart Lock Gear Replacement: step 2, image 3 of 3
      • Lift the cover off the device and set to the side.
      • The cover contains the speaker which is connected to the motherboard so do not pull to far apart.
      • Remove the gears as shown.
      Ask FixBot
12 other people completed this guide.
Author
with
William Fink
841 Reputation
3 Guides authored
USF Tampa, Team S11-G6, Passmore Fall 2017 Member of USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Members
36 Guides authored
9 Guide Comments
The tittle of this topic is: August Smart Lock Gear Replacement, but I don't see any spare part replacement at all!
Walter Quintero - Reply Share
Any tips on where to get replacement gears?
Byron H - Reply Share
The gear connecting the motor is cracked. I'd also like to know where to get parts other than buying another broken August lock that's broken in another way.
Robert F. Jobin Jr. - Reply Share
Robert, where you able to find this replacement gear? Mine broke this week and having a hard time to find the part. Thanks
Luiz Cavalcante - Reply Share
Anyone find gear replacements? The. Am on the motor shaft cracked on mine
pennytrotz - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 149
All Time: 14,605
