August Smart Lock Speaker Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
112
All Time:
2,108
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will teach you how to replace the speaker that are located within the device. The speaker can malfunction causing you to not hear the proper sounds from the lock.
Tools
    1. August Smart Lock Speaker Replacement, Speaker: step 1, image 1 of 3 August Smart Lock Speaker Replacement, Speaker: step 1, image 2 of 3 August Smart Lock Speaker Replacement, Speaker: step 1, image 3 of 3
      • Flip the device so the back cover is facing you.
      • Undo the latches on both sides to remove the metal cover.
      • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
      • To unscrew all of the screws, you will need to close the latches again.
      • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
      Ask FixBot
    2. August Smart Lock Speaker Replacement: step 2, image 1 of 3 August Smart Lock Speaker Replacement: step 2, image 2 of 3 August Smart Lock Speaker Replacement: step 2, image 3 of 3
      • Use the metal spudger to pry the plug off of the motherboard.
      • The plug can be dislodged when prying it from the side.
      Ask FixBot
    3. August Smart Lock Speaker Replacement: step 3, image 1 of 3 August Smart Lock Speaker Replacement: step 3, image 2 of 3 August Smart Lock Speaker Replacement: step 3, image 3 of 3
      • Warm up the iOpener.
      • Do not place the iOpener in microwave for more than 30 seconds.
      • Place the iOpener heating pad over the speaker and let sit for a few moments.
      • Using the metal spudger, pry some of the glue off the hinges holding the speaker in place.
      Ask FixBot
    4. August Smart Lock Speaker Replacement: step 4, image 1 of 2 August Smart Lock Speaker Replacement: step 4, image 2 of 2
      • Once the speaker looks mobile, flip the cover over and push below the speaker to pop it out.
      Ask FixBot
2 other people completed this guide.
William Fink
841 Reputation
3 Guides authored
USF Tampa, Team S11-G6, Passmore Fall 2017 Member of USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 112
All Time: 2,108
