Asus Padfone 2 battery will not hold a charge
The phone has been plugged in and it is still not charging
Wrong Charger
The wrong charger might have been used. In order to ensure that you have the right one, inspect the charging port on both the phone and charger to confirm that the charger is the right one for the device you are trying to charge. If this has been confirmed and the device still does not hold a charge, read on.
Bad Outlet
Try plugging the charger into another outlet, there might be nothing wrong with the phone.
Broken Charger
If you have tried plugging the charger in another outlet and it still is not charging the device, check the charger for any signs of damage and wipe it clean. Try plugging it back in, if this does not work, the charger may be broken and will need replaced.
Faulty Battery
The battery of the device might be placed incorrectly,take it out and insert it correctly following the Asus Padfone 2 Battery Replacement. If this doesn't work try replacing the battery following the same guide. Unplug the device and plug it back in just in case of bad connection between the device and the charger.
Vibration Issues
Asus Padfone 2 vibrate mode does not work
Vibration Setting Might Not Be Turned On
Check phone settings to make sure that the vibration mode is selected.
Vibration Motor Has Malfunctioned
The A68 vibrator will need to be replaced. See Asus Padfone 2 Vibrator Replacement for repair details.
Display Screen Issues
Asus Padfone 2 shows no display or is non-responsive
Phone needs to be restarted
The phone might be overworked from running too many applications, try restarting it.
Broken Screen
A screen showing signs of a crack or worse will affect the display of your device, replace the screen with Asus Padfone 2 Screen Replacement
Mobile Network Not Working
Asus Padfone 2 wireless network is not working
A68 Sub Cable Broken
If your mobile network is not working there is a good chance that you have broken one of the A68 Sub Cable. Replace your sub cable with Asus Padfone 2 A68 Sub Cables Replacement
Camera not displaying images
Camera shows blurry images or no images at all
Dust on the lens
Check the camera for debris and wipe it clean
Restart your device
If the camera debris has been wiped and the camera stills shows blurry images, try restarting the device.
Broken camera
The camera might be broken if restarting the device did not fix the problem, try replacing your camera with Asus Padfone 2 Camera Replacement
Author
with
Opeoluwa Oyeleke
1 Reputation
0 Guides authored
USF Tampa, Team 5-4, Mcgee Fall 2014 Member of USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Members
48 Guides authored
2 Comments
what is a picture of a wrench mean?
cordell hall - Reply Share
need help what does a picture of a wrench mean
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 28
All Time: 5,131
